No, no standard BIOS. That's why I wrote "5 disks". Upgrade with
 sudo /usr/local/bin/freenas-update -R updateafter I login to the NAS.
Maybe the non-standard BIOS is key. I can look where I have it in a backup, but it's more than 5 years ago, so might take some time.
EDIT: Found it. Here is the description:
https://homeservershow.com/blog/byo...server-build-and-bios-modification-revisited/
Get the necessary HP software here:
https://www.msdonkey.com/server/bios-for-hp-proliant-microserver-g7-n54l/
You can look at my signature for the HD cage I used in the fifth slot.
Ok, thanks for those links. It was interesting reading and ended up with me having an all nighter.
Your links talked about modding the 2011 bios, but when I went to HP to try and download the bios file, I discovered that there was a newer HP bios the was released in 2013. So after a lot of hassle with the HP utility that refused to flash any of my USB flash drives, telling me that the drive was write protected, I managed to flash a SD card and then clone that onto a USB drive.
I first upgraded to the new HP 2013 bios. Rather than then trying to go through the whole FreeNAS upgrade process again, I have just been using the FreeNAS 11.2 install USB which I know has failed if it doesn't show the BTX version number within seconds of displaying the white screen.
I should also mention that I disconnected my ZFS drive pool, so the only drive installed was the USB install drive.
Well the 2013 vanilla bios failed on first boot.
I then played around with the USB bios setting to see if could get it to boot, but each setting I tried failed.
The next thing I tried was updating the bios again with the modded version. As I understand it, all the mod does is to expose two more settings tab, allowing you to fine tune some of the more advanced settings. At this stage I have not changed any of these other settings.
Again I tried the 11.2 install, but again it failed to get past the white screen.
It seems to me, that if a bios setting is wrong the most likely culprit must be a USB setting as it is the USB install drive that is failing to be read. I am using a SanDisk Ultra Fit USB drive that has an led on the front, that indicates disk activity. I don't see the led light at all when booting with the 11.2 install drive. When I am booting 11.1 and also when I go through the upgrade process I see the led flicker regularly, until with the upgrade we get to the second reboot.
What would be useful from the guys who have successfully upgraded to 11.2 is their current USB setting plus a note of all the modded setting that they have changed. If you are not sure what you have changed, perhaps you could take some pictures of the pages you know you have changed so I can compare with my current settings.
I know this could be time consuming, but I would very much appreciate your help.
