flashdrive
- Apr 2, 2021
I have bought 2 x HP 533FLR-T 2-Port 10GbE PCI-Express x8 Network adapter cards
Both of them fail to show up in TrueNAS.
I have not connected a LAN cable to either of them.
How may I install this card?
What I have tried:
1. shell - ifconfig
em0 is the mainboard onboard NIC
@truenas[~]# ifconfig
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: em0
options=81249b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,LRO,WOL_MAGIC,VLAN_HWFILTER>
ether d0:XX
inet 192.XX netmask 0xffffff00 broadcast 192.XXX
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 pr
2.
as per https://www.ixsystems.com/documentation/freenas/11.2/system.html#tunables
and here:
(is this a typo: "...loadable bxnt..." )
> BNXT(4) FreeBSD Kernel Interfaces Manual BNXT(4) NAME bnxt -- Broadcom NetXtreme-C/NetXtreme-E Family Ethernet driver
Is this setup wrong?
if_bxe_load > YES
if_bnxt_load > YES
/boot/loader.conf
shows
# Load some hardware modules that don't fit into kernel.
if_bnxt_load="YES"
if_qlxgbe_load="YES"
What I have tried:
1. shell - ifconfig
description: em0
ether d0:XX
status: active
inet6 ::1 pr
2.
and here:
USB 3 - 5 GBit network connector e.g. QNAPs QNA-UC5G1T - recommendable ?
Hi, I do not need a 10 GBit connection. Client and host should be upgraded to 5 GBit. How does FreeBSD / TrueNAS operate with USB 3 - 5 GBit network connector e.g. QNAPs QNA-UC5G1T ? I was thinking of USB 3 connection for the host because of re-useability compared to a PCI E add in card. If...
www.truenas.com
if_bxe_load > YES
if_bnxt_load > YES
/boot/loader.conf
shows
if_bnxt_load="YES"
