[HowTo] Default Terminal to Clear Output upon File Close
zoomzoom
Updated 2018.08.05: Added xterm-256color info​
FreeBSD, by default, keeps file output on screen after a file has been closed, which is the opposite of how xterm operates in Linux, and if one prefers the Linux style of xterm, which clears file output from the screen once the file has been closed, perform the following:
Solution 1 (Recommended)
Create & apply a .termcap user file:
  1. ~/.termcap
    1. nano ~/.termcap
    2. Copy, then right click in the terminal to paste:
      xterm|X11 terminal emulator:\
      	:tc=xterm-clear:
      xterm-256color|xterm with 256 colors and clear:\
      	:Co#256:pa#32767:\
      	:AB=\E[48;5;%dm:AF=\E[38;5;%dm:tc=xterm-clear:\
      	:te=\E[2J\E[?47l\E8:ti=\E7\E[?47h::tc=xterm-clear:\
      	:tc=xterm-new:tc=xterm-clear:
    3. Save & exit: [CTRL]+ [X], [Y], press [ENTER]
  2. ~/.profile
    1. nano ~/.profile
    2. Add: TERMCAP=$(< ${HOME}/.termcap); export TERMCAP
  3. Reload terminal to apply: source ~/.cshrc
See termcap(5) man page for additional info
See this for xterm-256color difference, this for defining :te & :ti, and this for defining :tc
Solution 2
Modify /usr/share/misc/termcap
  1. nano /usr/share/misc/termcap
    1. xterm
      1. [CTRL]+ [W], type: xterm|, press [ENTER]
        • This should bring you to line 3013
          3013:  xterm|X11 terminal emulator:\
          3014:	  :tc=xterm-new:
          3015:  #   :tc=xterm-r6:
      2. Change line 3014: :tc=xterm-clear:
    2. xterm-256color
      1. [CTRL]+ [W], type: xterm alias 3, press [ENTER]
        • This should bring you to line 2884
          2884:  xterm-256color|xterm alias 3:\
          2885:	  :Co#256:pa#32767:\
          2886:	  :AB=\E[48;5;%dm:AF=\E[38;5;%dm:tc=xterm-new:
      2. Change line 2886: :AB=\E[48;5;%dm:AF=\E[38;5;%dm:tc=xterm-clear:\
      3. Add line 2887: :te=\E[2J\E[?47l\E8:ti=\E7\E[?47h::tc=xterm-clear:\
      4. Add line 2888: :tc=xterm-new:tc=xterm-clear:
  2. Save & exit: [CTRL]+ [X], [Y], press [ENTER]
  3. Rebuild termcap-database: cap_mkdb /usr/share/misc/termcap
It also appears [HOME], [END], & [DELETE] keys lost their bindings in FreeNAS 11, and while these can be added back via ~/.termcap, it's simpler to add them to ~/.cshrc
Modify ~/.cshrc
  1. nano ~/.cshrc
  2. Copy, then paste to prompt section:
    	bindkey "\e[1~" beginning-of-line
    	bindkey "\e[3~" delete-char
    	bindkey "\e[4~" end-of-line
    • Example:
      	# Shell #
      if ($?prompt) then
        set prompt		= "[%{\033[34m%}%N%{\033[0m%}%{\033[32m%}@%{\033[0m%}%{\033[34m%}%m%{\033[0m%}] %{\033[34m%} %~$
        set promptchars   = "%#"
        set filec
        set history	   = 1000
        set savehist	  = (1000 merge)
        set autolist	  = ambiguous
        set mail		  = (/var/mail/$USER)
        set autoexpand
        set autorehash
        if ( $?tcsh ) then
      	bindkey "^W"	backward-delete-word
      	bindkey -k up   history-search-backward
      	bindkey -k down history-search-forward
        endif
      endif
  4. Reload terminal: source ~/.cshrc
m0nkey_
Just so it survives software upgrades, add this to the .termcap file of your users home directory instead. :)
zoomzoom
I added instructions on a user ~/.termcap, however does the shell auto load it first prior to going to the main termcap file, or does an export parameter need to be added to ~/.profile or /etc/profile?
zoomzoom
Updated with the missing piece, which is the editing of ~/.profile.
zoomzoom
Updated with xterm-256color info
