How to use Vlan on FreeNAS 11-u4?
Kennyvb8
Mihalich
You can use different vlans for different services, if it possible for you.
Kennyvb8
huh?!!? as i linked, someone has done it before, but useing that guide makes me haveing no connection to the router and outside world. hence why i made this post. coul dyou ellaborate what you mean ?
Mihalich
Add a VLAN, configure it in the tab "interfaces", later in the service, you can specify the address on which to listen to the selected service. The port on the switch must be in trunk mode.
Sorry, I don't understand that you can't configure at what stage.
Kennyvb8
Done and done!
the problem is how to make the jail use vlan, and make it successfully connect to the router/outside world
when ever i make a vlan in the tab "interfaces" it takes 1 ip adress, correct? even that i can't see been leased/static in my router.. and therefore when i try following that guide on how to enable the vlan in jails the jails can't connect anywhere at all
Mihalich
In the settings interface your VLAN is it possible to specify a gateway? If not, then you need to write static routes for each VLAN.
Kennyvb8
Erhm. In FreeNAS 11-u4 No, this is not possible.
But there is a static routes tab next to interfaces.
But how to use?
Mihalich
Your vlan 250 has a network (for example: 192.168.250.0/24) and a gateway (192.168.250.1)
The route will be like this:
Destination network: 192.168.250.0/24
Gateway: 192.168.250.1
Description: VLAN250 (it is optional)
Kennyvb8
done!
i figured out that i can't have VIMAGE enabled in jails ?!? when i uncheck it, do the echo "250" > iface into the .jail.meta/iface it works now!
what is VIMAGE anyway ?
Mihalich
I don't know, some crap for virtualization.
