How to update SCALE using CLI
stavros-k
So in the last nightly the Settings menu is broken. So you can't update form the WebUI.
The bug is still in progress, but if you already are in the broken update, you can check and update from CLI.
For this you need to have SSH already enabled. (or use a monitor and keyboard directly connected to the machine)
Connect with SSH to truenas Scale and do the following
cli
system update update
* uncomment train and set to TrueNAS-SCALE-Angelfish-Nightlies
* uncomment reboot and set to true
* Press F10 and save
Wait until the file is downloaded, unpacked and the server rebooted.
Hopefully this will help someone.
