how to update plex on 11.2 -rc2?
RJGamer1002
Jailer
Not strong, but bad
pkg install ca_root_nss and try again.
RJGamer1002
so that fix it and now I'm getting an error when i run this command: ./PMS_Updater.sh -vv -a and I'm not sure if this command is even working: chmod 755 PMS_Updater.sh.
gt2416
pkg install wget and try again
RJGamer1002
that work but it now saying it can not find freeBSD download link and I'm still not sure if the chmod 755 PMS_Updater.sh is working still.
I don't know why you're wondering this--if it isn't giving an error, it's working. And if you're able to run the script at all, the permissions are set correctly.
As to the update itself, why the pathological desire to have Plex so up to date? For a standard jail, use pkg upgrade. For a plugin, wait for the plugin to be updated and upgrade then.
gt2416
If you REALLY want to update plex you can do it manually. Go to their website and get the FreeBSD version. Backup and unzip that in the install location which is /usr/local/share/plexmediaserver
Run this command (Dont know if you actually need to but I do this cause it in my notes):
ln -s /usr/local/share/plexmediaserver/libpython2.7.so.1 /usr/local/share/plexmediaserver/libpython2.7.so
And your done.
