SOLVED How to run VirtualBox inside FreeNAS
Bostjan
In FreeNAS GUI in Jails -> Template tab there is VirtualBox template available. I have been googling about VirtualBox inside FreeNAS but I get results for FreeNAS inside VirtualBox.
Does anybody have any good link for tutorial hot to use this feature in FreeNAS GUI.
Thank you.
Bostjan
I wanted to install a virtual machine in Virtualbox but I get a blank screen.
I have installed the jail and Virtualbox, but I get a blank screen in console tab (In Chrome and Edge I get blank screen, in Firefox I get notice that I need a plugin).
What else do I need to install, so I'll be able to acces the virtual instance.
There's probably more than one way to do this. I just use a VNC client. In your VM settings, go to Display -> Remote Display, make sure the box is checked, and enter a port number. You can also set a password if you wish. Then use the VNC client of your choice to connect to the IP of your VirtualBox jail, and the specified port.
