Shoop83
- May 2, 2018
Hello!
I've had a pool go bad to the point I can no longer mount it in the GUI without causing a kernel panic. I need to save the data in the pool if at all possible.
I've been able to mount the pool (BigVault) as read only through the shell, but it is not visible in the GUI and I can't figure out how to get it visible there to share it with my windows machine to copy the data so I can destroy the pool and begin again from scratch on my FreeNAS machine.
A few questions I just can't seem to figure out from the documentation, forums, tutorials, etc...
1. How do I view the file directory in the read-only mounted pool?
2. How do I use rsync to copy the files from my read-only pool to an external usb harddrive? (Is there a better command to use to do this?)
3. Will using rsync copy the files so I can access and use them on a windows machine once the copy is finished?
Thanks
Thanks
