How to recover accidentally deleted file?
Alex Wu
I am using FreeNAS 8.3.0 release P1-X64 (r12825)
Anyone can help if I need to undelete accidentally shift-del items in CIFS share? I cannot see any deleted file in recycle bin. The file is extremely important, please help!!
Alex
If you have a recycle bin setup in CIFS, then it should be in .recycle of the share. If you didn't setup the recycle bin there is no way to recover the file.
Alex Wu
I have setup recycle bin but cannot found the "just" deleted file. Any tools and way to recover? I am willing to pay if any method can help. Many thanks.
You have to go to .recycle and find the file in there. It should be the same location as the old file. So if the old file was in /Cyberjock/Personalfiles/Igotdeletedonaccident.txt you should be able to find the file in .recycle/(usernamewhodeletedit)/Cyberjock/Personalfiles.
If it isn't there than you aren't looking at the right place or something. Files in the recycle bin are never deleted(I have a script that deletes everything after 3 days automatically).
The recycle bin is the ONLY way to do the recovery.
If you want to pay me to recovery the file from the recycle bin, I'm game. I'll want payment up front and of course I can't guarantee the file will be there in the event that you've misconfigured the recycle bin or something.
D
dlavigne
Guest
This is a classic example of why ZFS snapshots are a wonderful thing.
Sir.Robin
Yah! Snapshots rock :)
Durkatlon
I think the problem here is that shift-del was used to delete the file(s), which is Windows shorthand for "delete-without-using-the-recycle-bin".
Dusan
Samba doesn't care about delete or shift-delete. I you enable the network recycle bin all deleted files will be moved there, even those you shift-deleted (try it).
Mguilicutty
So how does one empty the recycle bins? Just delete them?
Yep. I do a script that empties stuff after 3 days :P
Mguilicutty
Do you delete ".recycle" or just the contents? I deleted about 1.5TB last night and was wondering where all that space went...
My script deletes just the contents.. but it doesn't matter what you do.
