How to read CPU stepping info via CLI
Xavi
Have been enjoying FreeNAS a lot for the last 3 weeks since installation.
I bought a 2nd Xeon, same model, to upgrade my FreeNAS box but it seems it was a different stepping so FreeNAS kept spitting errors on bootup.
I plan to buy a 2nd CPU that matches the stepping of the CPU currently in the box and as I was ready to shut it down and pop open the server and remove heatsink paste, etc i wondered:
Is there a command i can use to read the CPU stepping info from the shell?
I used
# sysctl -a | egrep -i 'hw.machine|hw.model|hw.ncpu'
at first but i doesnt give out too many specifics, just usual model number and speed, but no stepping information.
If not i guess ill just read the actual etching on the cpu itself if i must but for the sake of information and knowledge i wanted to know if i can just obtain this information from FreeNAS OS without incurring any downtime from: a reboot into bios to see the stepping info there, a shutdown and dissection of the actual hardware to read it from the cpu top and probably have to go buy new thermal paste also.
Thanks in Advance!
bigphil
dmesg | grep Stepping
