I'm sure many people will be interested. I scanned eBay for 2U and 3U cases and there is a lot available for $200 shipped. With power supplies. There is complete systems with motherboards for little more.
All this looks good, but how can I tell if it is going to work for me? I guess I need to look at MB form-factor. If I picked X10SL7-F for my build, it's micro-ATX
Does it mean I can fit any bigger case?
Should I look at cases with power supplies on a side?
2U cases will fit all the drives I will ever want, should I still go with 3U for some reason?
Are those caddies hot-swappable and easy to connect? Do they fit standard 3.5 hard drives?
Any other pointers or suggestions on how to tell if case will or will not work?
Example:
http://www.ebay.com/itm/Supermicro-...182?pt=LH_DefaultDomain_0&hash=item5676a44f6e
From the look of it - I like it. Plenty of HDD slots. But the motherboard is larger than X10. Does it mean I can use this case without a problem?
Example:
