How to map WD network drive to TrueNAS Scale Plex app
Gti4life
Hi Guys,
I recently installed TrueNAS scale and the Plex APP
How do I point the server to my media folder on my western digital ex2ultra ?
I tried mounting using Shell but I keep getting a permission denied error
I used the below commands
# mkdir /mnt/wdmedia
# mount -t cifs //192.168.0.220/media /mnt/wdmedia
any help would be greatly appreciated
kherr
Put them on the TN box ??????
NugentS
It'll be permissions - its always permissions
You probably need to add a username / password in fstab and a credentials file. Except that you almost certainly can't use fstab as thats likley to be replaced every boot.
Can you enable guest access on the WD? That MIGHT work
If the guest access works, then mount the share at boot time using an post-init script
wildone81
For some reason, this feels like approaching the problem backwards, as the WD EX2 Ultra already supports running Plex on it. What is the TrueNAS Scale system running on that would prevent you from just moving everything over? And since it looks like you can use the EX2 as an iSCSI target, why not use that to map things over?
Gti4life
Hi Wildone8,
I am running scale on a PowerEdge R720xd , Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz with 96Gib ram.& currently with 20tb (12x 2tb drives)
Running plex on the WD was not a great experience
I am planning to eventually move everything over to Scale once I start replacing the 2tb drives with18tb’s
I am not familiar with the iSCSI target how would that work ?
Thanks
wildone81
That part I haven't figured out, WD has a document detailing how to set that side up as the target, but I myself am not as familiar with setting up the initiator side of the equation, I think I saw a JIRA ticket requesting the appropriate application being made available for setting up TrueNAS as the initiator.
Gti4life
Hi NugnetS,
I do have public access enabled for that media share
I feel like the permission issue is with the /mnt/
wildone81
Hi NugnetS,
It isn't going to be an issue with the TrueNAS /mnt side because it is already 755 owned by root, it is all on the WD EX2 side not accepting the connection. The following seems to be detailing what you want to accomplish:
Gti4life
Hi Guys,
Thank you for all the suggestions
I ended switching over to the Truecharts Plex app and I was able to add my wd storage as an NFS share
Now I just have to figure out how to migrate the metadata from my windows plex
