dureal99d
- Aug 3, 2017
This is a how to install Nextcloud 12.3 with all checks passed on FreeNAS 11.
This is a rewrite of the original post https://forums.freenas.org/index.php?threads/how-to-nextcloud-10-w-apache-php-and-mariadb.46111/ with a few added adjustments where needed to make this fully functional.
I know this works as I have re-emulated this 4 times today to insure its accuracy
Somethings may need to be edited based upon volume name but for the most part plug and play
a great thanks to nathank1989 and all of those that have contributed.
Creating the Dataset & Jail
Create Dataset
Within FreeNAS Userspace:
Storage > Create ZFS Dataset
SQL Data
Add New user in FreeNAS space:
From the Storage Tab
Change Permissions On your Storage volume that houses your jail -> should look similar to this>>> /mnt/your drive name/db
Create a Jail
Jails > Add Jail
Jail Name: nextcloud
Ensure VIMAGE is checked*
*Unless you have and want to use a separate and dedicated NIC for the jail. The MoBo I use comes with additional network ports.
Add Storage to the same jail you just created
Jail: nextcloud
Jail: nextcloud
Setting primary cache In FreeNAS UserSpace Shell
F.A.M.P Installation
In this section we are going to install F.A.M.P, an iteration of LAMP (Linux, Apache, MySQL, PHP). I chose this because I, personally, haven't had much luck with nginx or lighttp. Another guide suggested lighttp and sqlite, but those might not hold up to a good amount of users storing a bit of data.
The setup is:
FreeBSD 11.0
Apache 2.4
MariaDB 10.1
PHP 7.0 or 7.1 **Do NOT install PHP7.2 - Nexcloud is absolutely incompatible with this version as of this writing **
This provides the basis for our webserving jail.
via putty ssh into the jail
From FreeNAS user space run command:
you will then see your jails, the run commander jexec "And the number of you jail" (example) "jexec 2"
Before we get started, let's add a few necessary packages as they aren't currently installed.
We will install each part of FAMP one-by-one. FreeBSD is the Operating system so good to go on that!
Install Apache 2.4
Setup in rc.conf
Start Apache
Okay lets Check to see that it works!!!!
open a web browser on a local machine (preferably the machine your on) on your network
Navigate to http://your_jails_ip and you should see the text "It Works!"
Install MariaDB 10.1
Setup in rc.conf
Start MySQL Service
Run Wizard Script
For this step read and follow prompts.
By default there is no root password, (
Login to MySQL, create Nextcloud DB and User
Enter the password you made for root during MariaDB 10.1 setup.
Enter each of these commands one-by-one, and make sure to include the semi-colon ;
Replace MAKEUP-YOUR-OWN-PASSWORD with a password of your choosing. You need this for the NextCloud setup.
PHP 7.0
Install PHP and associated modules
or perhaps you prefer
php 7.1
Configuring Apache for PHP7
Ensure that the rewrite and ssl modules are enabled (uncommented) in /usr/local/etc/apache24/httpd.conf.
in the httpd.conf file search for "ssl_module" by using the bellow command
To search the document
Then enter the name of the file you want to search within the document
To execute the command simply press enter it will find the filename
while still in the same document "httpd.conf"
Uncomment these 2 lines (delete the # at the start of the line) so it looks like this:
Remove php5 (if it exist)
Add php7:
while working in the same file after this line
Add this
While still in the same file search for:
Then Insert this code directly under:
Save & quit
Double check that you see libphp7.so in /usr/local/libexec/apache24
to do this simply search by executing the following commander
it should give you this feedback
if it does this lets move on!!!!!!!
now lets add a PHP handler
Paste this test in the 001_mod_php.conf file:
Save & Exit
Once you're done save and close
Restart apache
Configure PHP.INI
then uncomment and update the below values to match: (uncomment means to remove the # symbol before any line
CTRL+X, Y, ENTER
Restart Apache
Testing with PHPINFO()
Navigate to /usr/local/www/apache24/data/
Paste the below code into the info.php file
Save & Exit
Navigate to http://your jails ip/info.php
You should see a full page with all the information regarding your PHP installation.
Now lets Configure REDIS
The purpose is to update redis.conf to run on local socket
Execute command:
In the redis.conf file find the value
uncomment by removing the ; symbol from in front of the below values and edit to match
Add REDIS to rc.conf
Start REDIS
To run redis on a local socket,
Run
you should see redis.sock and mysql.sock in the feedback list.
If you see those two, you're ALMOST DONE!!
Now lets Install NextCloud 12.3
before downloading NextCloud 12.3 navigate to the default apache data directory
Download Nextcloud:
wget https://download.nextcloud.com/server/releases/nextcloud-12.0.3.zip
Unzip Nextcloud:
Give correct owner/ or rather modify the folder permissions:
Add virtual Host info :
Navigate to: /usr/local/etc/apache24/Includes
Touch file: (I used a cloud.* subdomain, if you're not using a sub, remove the 'cloud.')
make your secure file in this format (simply copy and paste):
Be sure to edit the YOURSITE.COM part of the below file with your domain info
(Example) if your domain is "tocool.no-ip.org" enter that and the domain name matches your touch file name.
Restart Apache:
Navigate to the website
You should now see the setup screen for NextCloud!!
If you do, give yourself a pat on the back. Now for the last steps...
NextCloud WebUI
Set up your admin account with a username and password you choose.
Storage & database
Now lets prepare the secure part of your domain file:
Copy and paste under the previously entered info
Lets Cache!!!
to setup a complete cache with redis and apcu:
then execute the following commands:
for php 7.0 and php 7.1
Additional steps for php 7.1
Navigate to:
Then change:
to
Lets fix some annoying apache errors!
to get rid of the below error message when restarting apache do the following:
Run command:
Search for "servername" it will look like the below, enter your jails ipaddress xxx.xxx.x.xxx:80
uncomment the ServerName line (uncomment simply means to remove the # or ; symbol from the front of any line) and wala message will be fixed.
restart apache
To add Domains that can connect from outside the lan:
navigate to: /usr/local/www/apache24/data/nextcloud/config/config.php
The file will look like the below:
restart apache using the following command:
I cant use VI, its too cryptic so I choose to use nano to set cron jobs, to do so execute the following:
Setup NC's cron jobs:
Now lets secure this server
SSL using Certbot:
Download/Install Certbot
Navigate to /usr/local/etc/apache24/httpd.conf
Find
I don't know what the below command does but it works:
Then add to the 2nd line of the file
Restart Apache:
Add Cron Job:
Okay once you finally logon to Nextcloud 12.3 using http and you enter the admin area you will see these errors!!!!
Have no fear if this error bothers you their is a fix
Force to https redirect:
Now lets introduce a redirect as in a redirect of http to https this mainly for on the lan as when accessed from the world wide web it automatically redirects to https and is not accessible via http.
be advised the https will say the connection is not secure when accessing from the lan using the direct ip.
Edit the .htaccess file by entering the following command:
While in the .htaccess file directly below this text:
Add:
Restart apache:
And VOILA! YOU ARE DONE!!!!!
so you can share with whomever you choose!!!!!!!!!!!!!
How to use NextCloud on a separate NIC
helpful commands and notes from install
to find a file:
enter command: find /usr -name "filename"
Create Dataset
Dataset Name = files Compression level = lz4 Enable atime = Off All other options default
SQL Data
Dataset Name = db Compression level = zle Enable atime = Off Record Size = 16K (Under Advanced Mode) All other options default
Username: mysql Shell: nologin Full Name: SQL User Password: anything
Owner: mysql Owner: mysql Set permission recursively
Create a Jail
Jails > Add Jail
Template: "------" IPv4 Address: 192.168.1.99 IPv4 Subnet: 255.255.255.0 Leave all else default
Jail: nextcloud
Source = /mnt/Cloud/files Destination = /mnt/files
Jail: nextcloud
Source = /mnt/Cloud/db Destination = /var/db/mysql
zfs set primarycache=metadata Cloud/db
The setup is:
FreeBSD 11.0
Apache 2.4
MariaDB 10.1
JLS
portsnap fetch extract
pkg install nano wget sudo
Install Apache 2.4
pkg install apache24
Setup in rc.conf
sysrc apache24_enable=yes
Start Apache
service apache24 start
pkg install mariadb101-server
Setup in rc.conf
sysrc mysql_enable=yes
Start MySQL Service
service mysql-server start
Run Wizard Script
mysql_secure_installation
you must create a new one when promted
just hit enter, and answer Y to all the following questions.Login to MySQL, create Nextcloud DB and User
mysql -u root -p
CREATE DATABASE nextcloud; CREATE USER 'nextcloud_admin'@'localhost' IDENTIFIED BY 'MAKEUP-YOUR-OWN-PASSWORD'; GRANT ALL ON nextcloud.* TO 'nextcloud_admin'@'localhost'; FLUSH PRIVILEGES; exit
PHP 7.0
pkg install redis php70 php70-bz2 php70-ctype php70-curl php70-dom php70-exif php70-fileinfo php70-filter php70-gd php70-hash php70-iconv php70-intl php70-json php70-mbstring php70-mcrypt php70-pdo_mysql php70-openssl php70-posix php70-session php70-simplexml php70-xml php70-xmlreader php70-xmlwriter php70-xsl php70-wddx php70-zip php70-zlib php70-opcache mod_php70
php 7.1
pkg install redis php71-ctype php71-dom php71-gd php71-iconv php71-json php71-mbstring php71-posix php71-simplexml php71-xmlreader php71-xmlwriter php71-zip php71-zlib php71-pdo_mysql php71-hash php71-xml php71-session php71-mysqli php71-wddx php71-xsl php71-filter php71-curl php71-fileinfo php71-bz2 php71-intl php71-mcrypt php71-openssl php71-ldap php71-ftp php71-imap php71-exif php71-gmp php71-memcache php71-opcache php71-pcntl php71 mod_php71
sysrc 'mysql_enable=YES' 'redis_enable=YES'
nano /usr/local/etc/apache24/httpd.conf
ctrl+w
ssl_module
LoadModule ssl_module libexec/apache24/mod_ssl.so LoadModule rewrite_module libexec/apache24/mod_rewrite.so
Find & Remove this >> LoadModule php5_module libexec/apache24/libphp5.so Replace with >> LoadModule php7_module libexec/apache24/libphp7.so
Add php7:
If you can't find libphp5.so, just add LoadModule php7_module libexec/apache24/libphp7.so to the last of the LoadModule section; right above where it says # Third party modules IncludeOptional ...
Add this
<IfModule php7_module> <FilesMatch "\.(php|phps|php7|phtml)$"> SetHandler php7-script </FilesMatch> DirectoryIndex index.php </IfModule>
<IFModule mime_module>
AddType application/x-httpd-php-source .phps AddType application/x-httpd-php .php
Save & quit
ctl+x y enter
find /usr -name libphp7.so
/usr/local/libexec/apache24/libphp7.so
# cd /usr/local/etc/apache24/modules.d # touch /usr/local/etc/apache24/modules.d/001_mod_php.conf # nano /usr/local/etc/apache24/modules.d/001_mod_php.conf
<FilesMatch "\.php$"> SetHandler application/x-httpd-php </FilesMatch> <FilesMatch "\.phps$"> SetHandler application/x-httpd-php-source </FilesMatch>
Save & Exit
CTRL+x, Y, ENTER
Restart apache
service apache24 restart
Configure PHP.INI
$ cd /usr/local/etc $ cp php.ini-production php.ini $ nano /usr/local/etc/php.ini
find cgi.fix_pathinfo=0 change from =0 to =1 find date.timezone = Change to your timezone (America/New_York) [ SEE: http://php.net/manual/en/timezones.php ] find post_max_size= change it to 1999M find upload_max_size= change to 1999M
opcache.enable=1 opcache.enable_cli=1 opcache.interned_strings_buffer=8 opcache.max_accelerated_files=10000 opcache.memory_consumption=128 opcache.save_comments=1 opcache.revalidate_freq=1
CTRL+X, Y, ENTER
Restart Apache
$ cd /usr/local/www/apache24/data $ touch info.php $ nano info.php
<?php // Show all information, defaults to INFO_ALL phpinfo(); ?>
Save & Exit
Execute command:
nano /usr/local/etc/redis.conf
"port" and change it from its default value to 0
unixsocket /tmp/redis.sock unixsocketperm 777
sysrc redis_enable=yes
Start REDIS
service redis start
Run
ls -al /tmp
Download Nextcloud:
Unzip Nextcloud:
unzip nextcloud-12.0.3.zip
chown -R www:www /usr/local/www/apache24/data/nextcloud /mnt/files
cd /usr/local/etc/apache24/Includes
$ touch YOURDOMAIN.com or org or gov.conf
$ nano YOURDOMAIN*
<VirtualHost *:80> DocumentRoot "/usr/local/www/apache24/data/nextcloud" ServerName YOURSITE.com RewriteEngine on RewriteCond %{SERVER_NAME} =YOURSITE.com RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent] #ErrorLog ${APACHE_LOG_DIR}/error.log #CustomLog ${APACHE_LOG_DIR}/access.log combined <Directory /usr/local/www/apache24/data/nextcloud/> Options +FollowSymlinks AllowOverride All <IfModule mod_dav.c> Dav off </IfModule> SetEnv HOME /usr/local/www/apache24/data/nextcloud SetEnv HTTP_HOME /usr/local/www/apache24/data/nextcloud Satisfy Any </Directory> </VirtualHost>
Restart Apache:
NextCloud WebUI
Storage & database
Data folder = /mnt/files
Database user = nextcloud_admin Database password = MADEUP_PASSWORD_FROM_BEFORE Database name = nextcloud Database host = localhost:/tmp/mysql.sock
cd /usr/local/etc/apache24/Includes nano YOURDOMAIN*
<VirtualHost *:443> ServerAdmin YOUREMAIL ServerName YOURSITE.COM DirectoryIndex index.php DocumentRoot /usr/local/www/apache24/data/nextcloud SSLCertificateFile /usr/local/etc/letsencrypt/live/YOURSITE.COM/fullchain.pem SSLCertificateKeyFile /usr/local/etc/letsencrypt/live/YOURSITE.COM/privkey.pem SSLEngine on # Intermediate configuration, tweak to your needs SSLProtocol all -SSLv2 -SSLv3 SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA SSLHonorCipherOrder on SSLCompression off SSLOptions +StrictRequire <Directory /usr/local/www/apache24/data/nextcloud> AllowOverride all </Directory> <IfModule mod_headers.c> Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains" </IfModule> </VirtualHost>
Lets Cache!!!
cd pkg install p5-Locale-gettext help2man texinfo m4 autoconf make config-recursive install -C /usr/ports/databases/pecl-redis make config-recursive install -C /usr/ports/devel/pecl-APCu
$ su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:set memcache.local --value="\OC\Memcache\APCu"' $ su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:set memcache.locking --value="\OC\Memcache\Redis"' $ su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:set redis host --value="/tmp/redis.sock"' $ su -m www -c 'php /usr/local/www/apache24/data/nextcloud/occ config:system:set redis port --value=0 --type=integer'
Navigate to:
nano /usr/local/www/apache24/data/nextcloud/config/config.php
Then change:
'memcache.local' => '\\OC\\Memcache\\APCu',
to
'memcache.local' => '\\OC\\Memcache\\Redis',
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message Syntax OK Stopping apache24. Waiting for PIDS: 80591. Performing sanity check on apache24 configuration: AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message Syntax OK Starting apache24. AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message when stating apache do the following:
Run command:
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
ServerName your jails ip:80
<<<<<<<put your serving machines ip address
restart apache
<?php $CONFIG = array ( 'instanceid' => 'ocwo6kfuc3ve', 'passwordsalt' => '9s6vbvue6FZ3g2AklNJS4Y3S4Y3FG1', 'secret' => 'gzWPI+QgwkIKkYQwmgfGk7oGW87N/jaytyODIEgVfBjCek0y', 'trusted_domains' => array ( 0 => '192.168.1.30', 1 => 'coolp.to.org',<<<add just like this ), 'datadirectory' => '/usr/local/www/apache24/data/nextcloud/data', 'overwrite.cli.url' => 'http://192.168.1.30', 'dbtype' => 'mysql', 'version' => '12.0.3.3', 'dbname' => 'nextcloud', 'dbhost' => 'localhost:/tmp/mysql.sock', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'nextcloud_admin', 'dbpassword' => 'maria10 database password', 'installed' => true, 'memcache.local' => '\\OC\\Memcache\\APCu', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => '/tmp/redis.sock',
setenv VISUAL /usr/local/bin/nano setenv EDITOR /usr/local/bin/nano
crontab -u www -e
*/15 * * * * /usr/local/bin/php -f /usr/local/www/apache24/data/nextcloud/cron.php
SSL using Certbot:
pkg install py27-certbot
certbot certonly --webroot -w /usr/local/www/apache24/data/nextcloud -d YOURSITE.COM
cd /usr/local/etc/apache24/httpd.conf
Find
Listen 80
and add underneath Listen 443
nano /etc/make.conf
DEFAULT_VERSIONS+=php7.0
Restart Apache:
Add Cron Job:
crontab -e
* 1 * * 1 ./usr/local/bin/certbot renew --quiet
- Your data directory and your files are probably accessible from the Internet. The .htaccess file is not working. It is strongly recommended that you configure your web server in a way that the data directory is no longer accessible or you move the data directory outside the web server document root.
- You are accessing this site via HTTP. We strongly suggest you configure your server to require using HTTPS instead as described in our security tips.
$ nano /usr/local/www/apache24/data/nextcloud/.htaccess
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
Add:
RewriteEngine On RewriteCond %{HTTPS} off RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
Restart apache:
Shut down the jail Click Edit Uncheck VIMAGE and select the NIC from the NIC drop down. Make sure your IP info didn't change. Start jail and try to access your cloud. If all went well you'd basically see nothing changed as it will work as expected.
to find a file:
