Steven Webb
- May 24, 2016
I have just stood up a second Freenas server with some extra 1TB drives striped together for 10TB of room. as its not very fast i would like my Main Freenas server to replicate each dataset to server 2 using the built in Rsync task.
So i went into the "Backup server" made a Dataset called Shared which is the same name as the one on the "main server" i then made the user Root and i checked that mode had everything checked and then checked recursivly.
Then i went and loged onto the Main Server clicked tasks then Rscnc Task now i clicked the button to add a new task. I set the path to the dataset i want backed up or synced.
select user to root
Rscnc mode is Rsync module
Direction is Push
description i just use the name of the data set
then Recusive selected
Times no
Compress yes
Archive no
delete no
quiet n
preserve extetended attributes no
delay updates yes
Then enable selected
when i look at the log it says that it can not find the module i have check that i have it the same i how its spelt on the dataset the capital letter in the same place etc. i made 11 different one`s one for each dataset and they all are saying they can not find the module. any ideas? like i said i thought it was permisions so im using root, made the folders with root and clicked to do it recursivly.
thanks
select user to root
Direction is Push
Times no
Compress yes
Archive no
delete no
quiet n
delay updates yes
thanks
