What I have are 4 x 1TB HDs setup as Raidz2.
Getting this error: smartd[95211]: Device: /dev/ada0, 1 Currently unreadable (pending) sectors
Here is some info you can work with (I've bolded parts I think are relevant) :
Now from what I've read seeing it is only 1 single sector I'm supposed to Write to this sector to get the disk to relocate it, right? I'm a bit lost how to do this, any help please?
[root@boxy] ~# smartctl -a /dev/ada0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: SAMSUNG SpinPoint F3
Device Model: SAMSUNG HD103SJ
Serial Number: S246JD2Z919929
LU WWN Device Id: 5 0024e9 00406fa02
Firmware Version: 1AJ10001
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Thu Jul 3 11:39:15 2014 SAST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 9240) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 154) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 1882
2 Throughput_Performance 0x0026 052 052 000 Old_age Always - 9004
3 Spin_Up_Time 0x0023 071 069 025 Pre-fail Always - 8836
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1798
5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0
8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3078
10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 626
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 4
192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0
194 Temperature_Celsius 0x0002 064 053 000 Old_age Always - 25 (Min/Max 14/47)
195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 1706
223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0
225 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 2071
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 90% 3078 1953523077
# 2 Extended offline Completed: read failure 10% 3069 1953523077
# 3 Short offline Completed without error 00% 3066 -
# 4 Short offline Completed: read failure 70% 3043 1953523077
# 5 Extended offline Completed without error 00% 3023 -
# 6 Short offline Completed without error 00% 3019 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
1 0 0 Completed_read_failure [90% left] (0-65535)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
gpart show
=> 34 1953525101 ada0 GPT (931G)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 1949330703 2 freebsd-zfs (929G)Code:
iskinfo -v ada0
ada0
512 # sectorsize
1000204886016 # mediasize in bytes (931G)
1953525168 # mediasize in sectors
0 # stripesize
0 # stripeoffset
1938021 # Cylinders according to firmware.
16 # Heads according to firmware.
63 # Sectors according to firmware.
S246JD2Z919929 # Disk ident.Code:
disk -t /dev/ada0
******* Working on device /dev/ada0 *******
parameters extracted from in-core disklabel are:
cylinders=1938021 heads=16 sectors/track=63 (1008 blks/cyl)
Figures below won't work with BIOS for partitions not in cyl 1
parameters to be used for BIOS calculations are:
Media sector size is 512
Warning: BIOS sector numbering starts with sector 1
Information from DOS bootblock is:
The data for partition 1 is:
sysid 238 (0xee),(EFI GPT)
start 1, size 1953525167 (953869 Meg), flag 80 (active)
beg: cyl 0/ head 0/ sector 2;
end: cyl 1023/ head 255/ sector 63
The data for partition 2 is:
<UNUSED>
The data for partition 3 is:
<UNUSED>
The data for partition 4 is:
<UNUSED>Now from what I've read seeing it is only 1 single sector I'm supposed to Write to this sector to get the disk to relocate it, right? I'm a bit lost how to do this, any help please?
