How to diable totp 2FA in shell
hafnix
Hi @all41id
Have Nextcloud 15 running in a Jail on Freenas 11.2, how can I disable totp 2fa in the shell?
Thx in advance
hafnix
scrappy
hafnix
Thank you scrappy but there seems there is a problem with occ which is not there.
Any hint ?
Then you'll need to find it. Since you haven't told us how you installed Nextcloud in that jail, we have no idea where the file would be. find / -name occ would tell you, though.
hafnix
I have installed it using your script, I found it in /usr/local/www/apache24/data/nextcloud
Here I ran the command again but got a message I have to use sudo -u www before the command
and so i did buit trhe correct paramter in the end was "twofactorauth:disable"
But then I got
Well, here is the Nextcloud documentation for the occ command, and sure enough, the disable command calls for a user ID and a provider ID. The latter, I'd expect, would be something you'd set when you enabled 2FA.
hafnix
Ok I do not know these values... and as it seems some config is missing I would like to disable the totp module globally
This should be possible according to the Nextclound docuumentation
