SOLVED how to check what RAID is used?
dirkme
I know it sounds silly, I might have already the answer, but need to have some knowledgeable person telling me to confirm ;-)
Thanks a lot for all your help ;-)
Dirk
What's an rtaid?
First, some terminology: What you're looking for is the pool's layout.
That is easily obtained by looking at the relevant section of the GUI or by running zpool status.
dirkme
zpool status (in terminal), didn't let me know what raid is used like z1 or z5, I found a z1 on the FreeNAS interface at volumes.
There it says: raidz1-0 (0 is most-likely the first disk)
gpsguy
Active Member
You should have seen raidz1-0 listed when you issued the zpool status command.
the "-0" designation is for your first vdev. A pool can be composed of one or more vdev's. The second one would have a "-1" and so on.
Please post your results from zpool status in code tags.
dirkme
root@voyager:~ #  zpool status
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h13m with 0 errors on Tue Oct 10 03:58:54 2017
   NAME  STATE  READ WRITE CKSUM
   freenas-boot  ONLINE  0  0  0
	mirror-0  ONLINE  0  0  0
	da0p2  ONLINE  0  0  0
	da1p2  ONLINE  0  0  0
errors: No known data errors
  pool: trustme
state: ONLINE
  scan: scrub repaired 0 in 5h28m with 0 errors on Sun Oct  1 05:28:58 2017
   trustme  ONLINE  0  0  0
	raidz1-0  ONLINE  0  0  0
	gptid/2976288a-877a-11e7-9bb5-bc5ff4ac2b1d.eli  ONLINE  0  0  0
	gptid/2a5e94f3-877a-11e7-9bb5-bc5ff4ac2b1d.eli  ONLINE  0  0  0
	gptid/2ba0dc85-877a-11e7-9bb5-bc5ff4ac2b1d.eli  ONLINE  0  0  0
	gptid/2c5475df-877a-11e7-9bb5-bc5ff4ac2b1d.eli  ONLINE  0  0  0
root@voyager:~ #
Oh, now I see it (embarrassing)
Does that mean it is 4 drives mirrored instead of raid 5 (3 drives for space and 1 for redundancy)
CraigD
Not mirrored, you have a single drive failure tolerance
Have Fun
dirkme
Have Fun
Thanks a lot, I was afraid I had them mirrored.
How come it says z1, shouldn't it say z5?
CraigD
The number after the z is the number of drive that can fail without data loss
dirkme
Wow, thanks a lot, I didn't know this.
Thanks a lot :)
...and there is no such thing as RAIDZ5. You're thinking of RAID5, which is kind of similar, but fundamentally different.
CraigD
Arwen
Not yet but I'm sure it will in the next 3 years
The new parity de-clustered ZFS RAID is really weird. It's being called DRAID in some of the preliminary documentation. Don't know what it will be called when it's finally released.
dirkme
thanks for the info.
