Hello FreeNAS gurus, I have a question that I can't seem to answer via search.
I have a new Dell R530 and a PERC H330 controller in HBA mode and 8 x 4TB WD Red Pro drives. To use the H330, I had to force FreeNAS to use the mrsas driver by editing the device.hints file. This had been working great for months, but there were several warnings on the forums that the mrsas drivers were not as reliable as the mpt drivers. My OCD took over and I sniped a Dell HBA330 on ebay for $35.
Now, I would like to undo my modifications to my device.hints file so that if there is ever an update, I don't lose that change and as a consequence, my pool, but I'm not sure what driver is currently being used with the HBA330. I swapped in the HBA330 and everything booted and pools mounted without skipping a beat. I can see on boot that is does mention the MPT firmware and presents the drive list in a completely different way than the H330, or even H730.
So my question is, how can I check what storage controller driver is currently in use? mrsas or mpt?
Thanks for your help, you guys rock!
