hugovsky
 - Dec 12, 2011
Thought I should share this with you all. Power-on hours just reset it self :)
=== START OF INFORMATION SECTION === Model Family: Hitachi Deskstar P7K500 Device Model: Hitachi HDP725050GLA360 Serial Number: GEA534RJ11JR4A LU WWN Device Id: 5 000cca 357ceca9e Firmware Version: GM4OA5CA User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Mon Nov 28 14:24:44 2016 WET SMART support is: Available - device has SMART capability. SMART support is: Enabled
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 141 3 Spin_Up_Time 0x0007 123 123 024 Pre-fail Always - 306 (Average 315) 4 Start_Stop_Count 0x0012 099 099 000 Old_age Always - 7672 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 131 131 020 Pre-fail Offline - 29 9 Power_On_Hours 0x0012 091 091 000 Old_age Always - 65792 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 132 192 Power-Off_Retract_Count 0x0032 091 091 000 Old_age Always - 11309 193 Load_Cycle_Count 0x0012 091 091 000 Old_age Always - 11309 194 Temperature_Celsius 0x0002 214 214 000 Old_age Always - 28 (Min/Max 14/45) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 246 - # 2 Extended offline Completed without error 00% 220 - # 3 Short offline Completed without error 00% 78 - # 4 Extended offline Completed without error 00% 52 - # 5 Short offline Completed without error 00% 65445 - # 6 Extended offline Completed without error 00% 65420 -
