How do I delete my posts?
You don't. Just stop using your account.
It wouldn't be fair to others that see the threads you've posted in because the flow of the posts will be broken.
mw2014
I don't want to remove anything I've posted.
I accidentally hit "reply" and the reply box opened. I can't find a way to close it and if I hit "Post Reply" it will post a blank reply.
I logged off, closed my browser. When I log back on and go to the thread, the box is still open.
I'm confused. Can you post a screenshot?
rogerh
The reply box is always there when you are logged in. With my browser at least, once you have logged in once you are always logged in on going to the forum, due, presumably, to the miracle of cookies. But you can remove the contents, if for instance it has a quote from a previous post in it.
mw2014
Thank you.
You are correct, the reply box appears once I log in, I didn't notice it until you pointed it out.
