DJ_TLG
- Jul 24, 2015
I am having issues setting up permissions for the user folders. I am creating a new dataset for each user. So I have a "home" dataset then I have a new dataset for user A "a" and for user B "b". What I want to do is that the users will have full control to their home folder and noone else will have access to it.(Windows equivalent of 700) The issue I am having is that the permissions keep reverting back to the windows equivalent of 774. I also would like to set it up in a way that any new dataset I create under dataset "home" will be created with the windows equivalent permissions of 700.
The "home" dataset is a cifs share and the option for home share is ticked. The share settings from smb4.conf is below.
[homes]
valid users = %U
path = /mnt/volume1/home/%U
comment = Home Directories
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
shadow:snapdir = .zfs/snapshot
shadow:sort = desc
shadow:localtime = yes
shadow:format = auto-%Y%m%d.%H%M-2w
shadow:snapdirseverywhere = yes
vfs objects = shadow_copy2 zfs_space zfsacl aio_pthread streams_xattr
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
