STREBLO
- Oct 23, 2015
I'm building a server for personal use. I plan use it as a home server mainly for backups and media. I'm also going to host an owncloud server, use plex, and possibly run a mail server as well. I want to have the ability to use it for other things I might not initially plan for so I don't want to under build it.
Here is my current build setup, i'm not sure if i need another fan or if the case fans are sufficient. I have only bought the WD Red's so far so everything else is changeable. I'm looking for some feedback as to whether there's a better choice out there, I've made a mistake or if i'm missing anything.
Not sure if I should have L2ARC and ZIL cache SSD's.
- 3x - Western Digital 6TB Red Hard Drives
- Fractal Design Node 804 Chassis
- Supermicro X10SL7-F Motherboard
- Intel Xeon E3-1231 v3 CPU
- 4x 8GB ECC RAM Samsung DDR3 1.35v-1600
- 16GB Supermicro SATA DOM (SuperDOM) Boot Device
- SeaSonic G-550 Gold Rated Power Supply
