Help with suitable VPN access to access truenas and jail components
alamoudi.moh
Apologies if this is a repeated question,
Basically, i would like to be able to access remotely my truenas and media jail services (sonarr, radarr, etc...) They are all installed in one jail
Which is the best suitable VPN way to do it.
Note: i am using zerotier for my other systems installed somewhere else (home Assistant, etc..) so if this is possible then it would be better
I would recommend using Tailscale... it works more-or-less the same as ZeroTier, but you can designate your TrueNAS Jail node to be a subnet router, which then makes your subnet/home network available to your Tailscale clients.
