Nitro626
- Mar 4, 2019
Hi All,
I have just upgraded my Dell r710 Nas to Truenas from freenas, I normally run Sonarr Radarr and Jackett in 1 jail/iocage these plugins tell Transmission in another jail what to download. However my UK isp blocks access to some of the sites Sonarr and Radarr try to access. So i have been using my free tunnelbear vpn on my windows desktop to access those sites. Transmission then has no problem downloading with no vpn.
So I thought I will just add my TunnelBear vpn to the Sonarr Radarr and Jackett iocage (My TB vpn account has 500mb a month free however this rolls over every month so I have 16GB of download available) so I checked TB vpn support pages and they have instructions for Linux TB Linux setup
I then followed this guide and tried to adapt it for TB vpn however it I get this error message when trying to start openvpn
I copied the TunnelBear Canada.ovpn config file text and pasted it into /usr/local/etc/openvpn/openvpn.conf I then copied CACertificate.crt UserCertificate.crt too the same location and chmod 0600 all 3 files. Those 3 files came from the TBvpn config zip file.
my openvpn.conf looks like this at the moment:
I can not find a guide for TB guide for truenas iocage anywhere, can anyone see an obvious mistake or am I going about this completely the wrong way?
/usr/local/etc/rc.d/openvpn start Starting openvpn. /usr/local/etc/rc.d/openvpn: WARNING: failed to start openvpn
client dev tun0 proto udp nobind ns-cert-type server persist-key persist-tun reneg-sec 0 dhcp-option DNS 8.8.8.8 dhcp-option DNS 8.8.4.4 redirect-gateway verb 5 auth-xxx@xxx.com-xxxxx (my login details) ca /usr/local/etc/openvpn/CACertificate.crt cert /usr/local/etc/openvpn/UserCertificate.crt remote ca.lazerpenguin.com 443 cipher AES-256-GCM auth SHA256 keysize 256
