The latest version of FreeNAS is 9.10.1, and that guide will work with it. If you're still having difficulties after trying what's suggested there, post back here, but give quite a bit more detail about exactly what you're doing, and what's happening. "It doesn't work" just doesn't give us anything to work with.
lol ik what you mean my bad well i followed the and for some reason im still not able to authenticate while using WinSCP i keep getting an error that says that no authentication options available but then in parenthesis it says that the server send public key
Double check you don't have spaces that sneaked into your copy and paste. I've had that happen and it didn't recognize my public key. Never used winscp before, but make sure your private key is loaded and accessible by winscp
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
