HELP with mount point + CIFS + Transmission
tripialos
Greetings.
What i am trying two achieve the last two days, is to install transmission torrent plugin on my NAS, and share the downloaded torrent files to my network. This is what i have done so far:
I have:
1 X 3TB disk named wdRED (main storage volume)
1 x 4GB usb disk named tank (for jail and plugins)
I created two datasheets on usb dongle (tank) and named them
tank (usb dongle)
a) jail (dataset)
b)plugins (dataset)
I successfully installed the jail plugin and then also successfully installed transmission plugin.
I downloaded a torrent for testing and all went well. The torrent was downloaded on the 4GB disk.
I then created a folder named torrent on the 3TB wdRED drive, configured the permissions and then i shared the folder to the network using CIFS.
From my computer i was able to view the folder and also write files create folders e.t.c
Now...i created a mount point between the transmission plugin folder (which is on the usb) and the 3TB wdRED disk.
I tried to download a torrent and it successfully downloaded to the wdRED disk HOWEVER...the folder torrent is now not accessible to the network...???
Since i mount pointed the folder to the jail/transmission the folder disappeared from my network (CIFS)
Any help would be much appreciated
