hunter
- Nov 24, 2013
I have my boot drive mirrored on two nearly identical sandisk thumb drives. 1 week ago when I upgraded FreeNAS, one of the two drives on the mirror became "UNAVAIL". I unplugged the drive and plugged it in again. At that point, I was able to "attach" it to the existing mirror and resilver. But the drive marked UNAVAIL remained and I could never see how to get FreeNAS to recognize that the hardware no longer existed.
Then the next time I upgraded FreeNAS, I had a similar problem. Here is zpool status. This time I tried to remove the same thumb drive and the FreeNAS web interface stopped responding and I had to press the reboot button on the hardware. It looks like this problem is not always happening to the same thumb drive. Can anyone see how to restore the mirror --or-- how to just go back to a single drive if the mirror is not going to be reliable during reboots (so far, it has not been) ?
pool: freenas-boot
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: resilvered 3.07G in 0h44m with 0 errors on Thu Feb 12 19:57:18 2015
NAME STATE READ WRITE CKSUM
freenas-boot DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
10004170420306317259 UNAVAIL 0 0 0 was /dev/da0p2
8267032784646246760 UNAVAIL 0 0 0 was /dev/da1p2
gptid/180c62b0-b315-11e4-b6e3-002590d7e3c7 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: DEGRADED
