HI guys
I am using FreeNAS-9.10.2-U6
I have mirror 0 with 2x 2Tb disks and i want to change to 2x4Tb disk
As I wasn't finding the replace or offline I remove one and install the new one.
Now I cant find the option to replace in the GUI
This does not work as I dont have the offline and replace option in the GUI
http://doc.freenas.org/9.10/storage.html
Also I have tried to update to the new version but plex was not working and I return.
[root@freenasHP ~]# zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h1m with 0 errors on Sat Jan 27 03:46:43 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/5281e09a-21f7-11e7-8f49-38eaa7a10742 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors pool: plex state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 16h16m with 0 errors on Sun Feb 4 16:16:21 2018 config: NAME STATE READ WRITE CKSUM plex DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 gptid/352d6fa5-358c-11e3-af34-38eaa7a10742 ONLINE 0 0 0 16787253956179915737 UNAVAIL 0 0 0 was /dev/gptid/35b4fa7f-358c-11e3-af34-38eaa7a10 742 mirror-1 ONLINE 0 0 0 gptid/d642db57-74e3-11e4-bcb7-38eaa7a10742 ONLINE 0 0 0 block size: 512B configured, 4096B native gptid/5c458af1-3fb7-11e6-8de4-38eaa7a10742 ONLINE 0 0 0 block size: 512B configured, 4096B native errors: No known data errors
