Help reimporting volume so I can replace a disk
ckuethe
Hardware: HP N40L (dual-core amd64 AMD Turion), 8GB, 4x Hitachi HDS5C3030ALA630 (3TB), 1x Corsair Force 3 SSD (240GB)
Build: FreeNAS-11.0-U3 (c5dcf4416)
I was silly and forgot to offline a disk that was throwing errors before replacing it. OK, I figured I'd put the old disk back in, actually offline and remove it, and continue replacing it. No joy. The volume fails to import on reboot and when I try import it by hand, I get this:
# zpool import
   pool: media
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
	devices and try again.
   see: http://illumos.org/msg/ZFS-8000-6X
	media										   UNAVAIL  missing device
	  raidz1-0									  ONLINE
		gptid/8621c5d2-f271-11e1-97d9-e4115b138d18  ONLINE
		gptid/f249fe7c-f309-11e1-a031-e4115b138d18  ONLINE
		gptid/14d22fbf-f264-11e1-84ee-e4115b138d18  ONLINE
		gptid/4b057049-f27f-11e1-a031-e4115b138d18  ONLINE
	Additional devices are known to be part of this pool, though their
	exact configuration cannot be determined.
The drives do all appear to be connected:
# glabel status
									  Name  Status  Components
gptid/8621c5d2-f271-11e1-97d9-e4115b138d18	 N/A  ada0p1
gptid/f249fe7c-f309-11e1-a031-e4115b138d18	 N/A  ada1p1
gptid/14d22fbf-f264-11e1-84ee-e4115b138d18	 N/A  ada2p1
gptid/4b057049-f27f-11e1-a031-e4115b138d18	 N/A  ada3p1
gptid/f58248e4-82af-11e4-b4e3-e4115b138d18	 N/A  da0p1
I'm just going to stop here and wait for further advice before I make the situation any worse. Help?
ckuethe
Plugged in the disk I tried using as a replacement into a spare sata port (ie. I now have all the original disks plus my intended replacement, and the volume now imports, though a little bit unhappy.
So I guess my question is how do I remove gptid/0c56691a-b153-11e7-9b30-e4115b138d18 from the volume and then use it as a replacement for gptid/8621c5d2-f271-11e1-97d9-e4115b138d18 (ada4) which has bad sectors?
# zpool status media
  pool: media
state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
	attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: resilvered 8.53M in 0h0m with 0 errors on Sat Oct 14 21:30:48 2017
	NAME											STATE	 READ WRITE CKSUM
	media										   ONLINE	   0	 0	 0
	  raidz1-0									  ONLINE	   0	 0	 0
		gptid/8621c5d2-f271-11e1-97d9-e4115b138d18  ONLINE	   0	 0	 3
		gptid/f249fe7c-f309-11e1-a031-e4115b138d18  ONLINE	   0	 0	 0
		gptid/14d22fbf-f264-11e1-84ee-e4115b138d18  ONLINE	   0	 0	 0
		gptid/4b057049-f27f-11e1-a031-e4115b138d18  ONLINE	   0	 0	 0
	  gptid/0c56691a-b153-11e7-9b30-e4115b138d18	ONLINE	   0	 0	 0
errors: No known data errors
GPTs
# glabel list
Geom name: ada0p2
Providers:
1. Name: gptid/0c56691a-b153-11e7-9b30-e4115b138d18
   Mediasize: 5999027552256 (5.5T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   seclength: 11716850688
   length: 5999027552256
   index: 0
Consumers:
1. Name: ada0p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada1p1
Providers:
1. Name: gptid/f249fe7c-f309-11e1-a031-e4115b138d18
   Mediasize: 3000592899584 (2.7T)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   seclength: 5860533007
   length: 3000592899584
   index: 0
Consumers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e2
Geom name: ada2p1
Providers:
1. Name: gptid/14d22fbf-f264-11e1-84ee-e4115b138d18
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   index: 0
Consumers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e2
Geom name: ada3p1
Providers:
1. Name: gptid/4b057049-f27f-11e1-a031-e4115b138d18
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   index: 0
Consumers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e2
Geom name: ada4p1
Providers:
1. Name: gptid/8621c5d2-f271-11e1-97d9-e4115b138d18
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   index: 0
Consumers:
1. Name: ada4p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e2
Geom name: da0p1
Providers:
1. Name: gptid/f58248e4-82af-11e4-b4e3-e4115b138d18
   Mediasize: 524288 (512K)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 17408
   Mode: r0w0e0
   secoffset: 0
   offset: 0
   seclength: 1024
   length: 524288
   index: 0
Consumers:
1. Name: da0p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 17408
   Mode: r0w0e0
da0 is the boot volume
ada0 is my new replacement disk
ada1-ada4 are the original disks
# dmesg | grep "ada.*device"
ada0: <TOSHIBA HDWE160 FS2A> ATA8-ACS SATA 3.x device
ada1: <Hitachi HDS5C3030ALA630 MEAOA5C0> ATA8-ACS SATA 3.x device
ada2: <Hitachi HDS5C3030ALA630 MEAOA5C0> ATA8-ACS SATA 3.x device
ada3: <Hitachi HDS5C3030ALA630 MEAOA5C0> ATA8-ACS SATA 3.x device
ada4: <Hitachi HDS5C3030ALA630 MEAOA580> ATA8-ACS SATA 3.x device
It looks like you striped that replacement disk to your pool. Unfortunately, this cannot be undone.
Back up your data and then read the following threads:
https://forums.freenas.org/index.php?threads/disk-added-as-stripe-instead-of-replacing.22788/
https://forums.freenas.org/index.php?threads/how-to-remove-striped-drive-from-a-zfs-volume.26847/
Welcome to the Forums!
joeschmuck
Old Man
