Okay, by now I would think that while it may appear confusing at first... the logic may start to seep in and it will get easier after you do it a few times...
So, I have to leave for dinner soon; but as far as the "Backups" folder and permissions I will let you try that out. But it is very similar to the "Users" folder except we should not have to set any rights for sub folders once the main "Backups" folder is created and permissions are properly configured.
Hint: I would only have:
- "ServerAdmins" = "Full" Rights to This folder, subfolder and files
- "BackupOperators" = "Modify" Rights to This folder, subfolder and files
/Might just be my "God" complex, but the only personnel that would need "Full" Rights to anything are the "
ServerAdmins"...
Best of luck, I will try to check back in later on tonight.
