I have just upgraded my FreeNas 9.2.1.6 to FreeNAS 9.2.1.8, and on reboot all I am getting is this as an example:
lib/util_sock.c1199(get_remote_hostname)
Oct 18 12:28:14 freenas smbd[6284] matchname failed on 192.168.0.5
The number in square brackets changes by 1 at every try, and the ip address changes from 5 to 4 and back again.
The last ip address for my FreeNAS box was 192.168.0.28, so what is going on?
What can I do to tell freeNAS to look for the correct ip address?
Hardware:
Supermicro MBD-X9SCM-F-O Retail Motherboard (Intel C204 PCH Chipset, SATA, LAN, IPMI, Single Socket)
Intel Core i3 3220 Dual Core CPU 3.3GHz
16Gb kingston ECC Ram
x3 2TB Western Digital 7200rpm NAS drives in a raidz1 pool
x2 1TB Western Digital 5400rpm Green drives in a mirror-0 pool
Thanks
Hardware:
Thanks
