Hi all,
I am a complete noob regarding FreeNAS. I am having problem setting up some things but the biggest problem is connecting my PCs (My own and my HomeTheater PC) to Freenas. I am not sure what I am doing wrong. I've tried to read many guides and watch many YouTube videos on it but I don't know what I am doing wrong.
Anyways, when I try to login from my personal computer I can log in but I get this message on Freenas:
an 20 22:18:59 freenas dhclient: New IP Address (em0): 192.168.1.4
Jan 20 22:18:59 freenas dhclient: New Subnet Mask (em0): 255.255.255.0
Jan 20 22:18:59 freenas dhclient: New Broadcast Address (em0): 192.168.1.255
Jan 20 22:18:59 freenas dhclient: New Routers (em0): 192.168.1.1
Jan 20 22:20:39 freenas smbd[6443]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.3 != (NULL)
Jan 20 22:20:39 freenas smbd[6443]: [2015/01/20 22:20:39.075348, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jan 20 22:20:39 freenas smbd[6443]: matchname failed on 192.168.1.3
Jan 20 22:21:53 freenas smbd[6542]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.3 != (NULL)
Jan 20 22:21:53 freenas smbd[6542]: [2015/01/20 22:21:53.911804, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jan 20 22:21:53 freenas smbd[6542]: matchname failed on 192.168.1.3
Jan 20 22:23:05 freenas smbd[6695]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.3 != (NULL)
Jan 20 22:23:05 freenas smbd[6695]: [2015/01/20 22:23:05.423332, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jan 20 22:23:05 freenas smbd[6695]: matchname failed on 192.168.1.3
Jan 20 22:23:22 freenas smbd[6710]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.2 != (NULL)
What does it mean by "name mismatch"?
Here are my system and network settings:
Network/Global Config
Hostname: freenas
Domain: local
IPv4 Default Gateway: 192.168.1.1
Nameserver 1: 192.168.1.1
Everything else is blank and unchecked
Network/Interfaces
em0, Intel, DHCP checked, and Auto configure IPv6 checked
CIFS Settings
NetBIOS name: freenas
Workgroup: WORKGROUP
Description: FreeNAS Server
Local Master checked
Domain logons checked
Time Server for Domain checked
Hostname lookups checked (tried unchecking it but didn't help)
All the other setting were left at default
General
Protocol: HTTP
Certificate: blank
WebGUI IPv4 Address: 0.0.0.0
WebGUI IPv6 Address: blank
WebGUI HTTP Port: 80
WebGUI HTTPS Port: 443
HTTP>HTTPS: checked
I have created my a user for myself named: Luis
I put myself under: wheel
I checked Permit Sudo
Windows is the Dataset I am trying to share. I put Owner: Luis and Owner Group: Family (this group includes user names of all my family at home). Apply mode is checked. Permission type is Windows.
This is the info of my PC
Computer Name: Luis
Full Computer Name: Luis
Computer Description: Luis
I login to my Windows 8.1 Update through Microsoft Account.
Although I am able to go into my folders on my personal PC. I am unable to go into my folders on my Hometheater PC. I get denied.
I made a user name called HomeTheaterPC and put it under the primary group called HomeTheater which includes myself and HomeTheaterPC.
The HomeTheaterPC has Disable password login checked so it doesn't need a password to go into my media folder that I am sharing.
So when I try to log into my media folder I am sharing. I get denied.
Jan 20 22:49:42 freenas smbd[13924]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.2 != (NULL)
Jan 20 22:49:42 freenas smbd[13924]: [2015/01/20 22:49:42.601329, 0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Jan 20 22:49:42 freenas smbd[13924]: matchname failed on 192.168.1.2
That is what I get on Freenas and in Windows it says: You do not have permission to access....
Media folder is set up differently than Windows shared folder. Owner is Luis and Group is HomeTheater. I have the Mode all checked (Owner, Group, Other). Permission type: Unix (I want to share it between Mac and Windows).
My Hometheater PC runs Windows 8.1 and I login with my Microsoft Account. Same as my personal PC to keep everything synced up.
Sorry for the long post. I was trying to be detailed to that you guys can help me. If I am missing any information please let me know. Thank you all for your help.
Hostname: freenas
Domain: local
Network/Interfaces
CIFS Settings
General
Protocol: HTTP
Certificate: blank
HTTP>HTTPS: checked
Computer Name: Luis
