I set up a new system, which seems to be working, and I would like help diagnosing error messages I'm getting via automatic email notification. I've gone through the manual, and some of the archives here, and based on those have tried a few things, outlined below.
The error message arrives in the email with subject "freenas.local security run output". It takes the form:
freenas.local kernel log messages:
> (ada1:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c0 f8 07 41 40 0e 00 00 00 00 00
> (ada1:ahcich3:0:0:0): CAM status: ATA Status Error
> (ada1:ahcich3:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF )
> (ada1:ahcich3:0:0:0): RES: 41 10 f8 07 41 40 0e 00 00 00 00
> (ada1:ahcich3:0:0:0): Retrying command
> (ada1:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 08 1c c4 40 0f 00 00 00 00 00
-or-
> (ada1:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 b0 b8 c2 c8 40 0e 00 00 00 00 00
> (ada1:ahcich3:0:0:0): RES: 41 10 b8 c2 c8 40 0e 00 00 00 00
repeated various numbers of times per day in the email with subject "freenas.local security run output". Similar "WRITE_FPDMA_QUEUED" wording as in this thread,
http://forums.freenas.org/threads/help-my-freenas-has-gone-south.9265/
though my SMART results (see below) don't seem to give any indications I'm able to interpret from the report.
The messages appear only for ada1. (My system has 4 drives; ada0 through ada3.)
System details:
Build FreeNAS-9.2.0-RELEASE-x64 (ab098f4)
Platform Intel(R) Pentium(R) CPU G2020 @ 2.90GHz
Motherboard: Supermicro X9SCM-B
Memory 16335MB (Kingston KVR16E11/8I, ECC selected for compatibility with motherboard.)
These are set up as a pool using the zfs mirror option, and are listed as drives ada0 through ada3.
All of the data on this machine are backed up elsewhere, so I have some leeway about how to proceed.
I've tried two things to understand what the error might mean:
(1) zfs scrub. Results:
pool: bits
state: ONLINE
scan: scrub repaired 0 in 0h6m with 0 errors on Sat Jan 11 07:46:06 2014
NAME STATE READ WRITE CKSUM
bits ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/85310526-73e9-11e3-bcee-002590d2fee7 ONLINE 0 0 0
gptid/85f3a2ca-73e9-11e3-bcee-002590d2fee7 ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/864970a8-73e9-11e3-bcee-002590d2fee7 ONLINE 0 0 0
gptid/869e70ea-73e9-11e3-bcee-002590d2fee7 ONLINE 0 0 0
errors: No known data errors
(2)
smartctl -q noserial -a /dev/ada1
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, [url="http://www.smartmontools.org"]www.smartmontools.org[/url]
Model Family: Western Digital Red (AF)
Device Model: WDC WD20EFRX-68EUZN0
Firmware Version: 80.00A80
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Jan 19 10:53:41 2014 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity was never started.
been run.
data collection: (27360) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 276) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 171 169 021 Pre-fail Always - 4416
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 33
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 406
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 7219
194 Temperature_Celsius 0x0022 134 118 000 Old_age Always - 13
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 307 -
# 2 Extended offline Completed without error 00% 271 -
# 3 Extended offline Completed without error 00% 247 -
# 4 Extended offline Completed without error 00% 223 -
# 5 Short offline Completed without error 00% 217 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Nothing really stands out for me.
This forum has some really knowledgeable people, let me thank you in advance.
-or-
System details:
pool: bits
state: ONLINE
bits ONLINE 0 0 0
(2)
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
