espenfjo
- Aug 15, 2022
Hi
I am planning on upgrading an old Synology to a TrueNAS installation, and I will be using 5x6TB + 5x4TB HDDs as my primary storage.
The system will be mainly used for archive, as well as Plex streaming and adding of Plex content. I will run a couple of VMs and Dockers/apps as well, but these should all be disk-friendly and not use much IO.
The plan for both the 6TB and 4TB drives are obviously RAIDZ2, but I am not sure if I should split these two vdevs into two pools or one joint pool.
Im also unsure if I should tweak the record size either up or down from the default 128k (probably 1M for the VM and media datasets?), and possible use a raidz2 SSD for my metadata store.
According to Wendell`s magic "find command" my current file sizes are distributed as follows:
1k: 5427993 2k: 5585454 4k: 7946447 8k: 6034212 16k: 4947933 32k: 3164960 64k: 1471199 128k: 531740 256k: 194017 512k: 85942 1M: 36179 2M: 27097 4M: 11684 8M: 7177 16M: 24798 32M: 7952 64M: 13971 128M: 337 256M: 334 512M: 1259 1G: 1343 2G: 1571 4G: 459 8G: 224
