Makaveli6103
- Mar 18, 2012
I have been have clicking issues for months and cannot figure out which hard drive it is. I ran some short smartctl tests. The results are blow. Also the last hard drive is a new WD Red I just installed last month.
=== START OF INFORMATION SECTION === Model Family: SAMSUNG SpinPoint F4 EG (AFT) Device Model: SAMSUNG HD204UI Serial Number: S2H7J1BZC16476 LU WWN Device Id: 5 0024e9 004824796 Firmware Version: 1AQ10001 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 6 Local Time is: Mon Sep 2 15:25:17 2013 CDT ==> WARNING: Using smartmontools or hdparm with this drive may result in data loss due to a firmware bug. ****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ****** Buggy and fixed firmware report same version number! See the following web pages for details: http://knowledge.seagate.com/articles/en_US/FAQ/223571en http://sourceforge.net/apps/trac/smartmontools/wiki/SamsungF4EGBadBlocks SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00)Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection:(19800) seconds. Offline data collection capabilities:(0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time:( 2) minutes. Extended self-test routine recommended polling time:( 330) minutes. SCT capabilities: (0x003f)SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 14 2 Throughput_Performance 0x0026 055 055 000 Old_age Always - 18266 3 Spin_Up_Time 0x0023 079 065 025 Pre-fail Always - 6442 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 860 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 12646 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 146 181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 2069 191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 50 192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0 194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 34 (Min/Max 16/40) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 49 223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0 225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 203278 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 12646 - # 2 Short offline Completed without error 00% 10598 - # 3 Extended offline Completed without error 00% 10598 - # 4 Short offline Completed without error 00% 10592 - # 5 Short offline Completed without error 00% 10591 - # 6 Short offline Completed without error 00% 10590 - # 7 Short offline Completed without error 00% 10589 - # 8 Short offline Completed without error 00% 10589 - # 9 Short offline Completed without error 00% 10588 - #10 Short offline Completed without error 00% 10587 - #11 Short offline Completed without error 00% 10586 - #12 Short offline Completed without error 00% 10585 - #13 Short offline Completed without error 00% 10584 - #14 Short offline Completed without error 00% 10583 - #15 Short offline Completed without error 00% 10583 - #16 Short offline Completed without error 00% 10581 - #17 Short offline Completed without error 00% 10580 - #18 Short offline Completed without error 00% 10579 - #19 Short offline Completed without error 00% 10576 - #20 Short offline Completed without error 00% 10575 - #21 Short offline Completed without error 00% 10574 - Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Completed [00% left] (0-65535) 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
=== START OF INFORMATION SECTION === Model Family: SAMSUNG SpinPoint F4 EG (AFT) Device Model: SAMSUNG HD204UI Serial Number: S2H7J1AZC17980 LU WWN Device Id: 5 0024e9 0048247a4 Firmware Version: 1AQ10001 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 6 Local Time is: Mon Sep 2 15:30:53 2013 CDT ==> WARNING: Using smartmontools or hdparm with this drive may result in data loss due to a firmware bug. ****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ****** Buggy and fixed firmware report same version number! See the following web pages for details: http://knowledge.seagate.com/articles/en_US/FAQ/223571en http://sourceforge.net/apps/trac/smartmontools/wiki/SamsungF4EGBadBlocks SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00)Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection:(19980) seconds. Offline data collection capabilities:(0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time:( 2) minutes. Extended self-test routine recommended polling time:( 333) minutes. SCT capabilities: (0x003f)SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 6 2 Throughput_Performance 0x0026 055 055 000 Old_age Always - 18204 3 Spin_Up_Time 0x0023 080 066 025 Pre-fail Always - 6285 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1022 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 14690 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 186 181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 119384 191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 123 192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0 194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 35 (Min/Max 15/40) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 34 223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0 225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 207057 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 14690 - # 2 Extended offline Completed without error 00% 12647 - # 3 Short offline Completed without error 00% 12641 - # 4 Short offline Completed without error 00% 12640 - # 5 Short offline Completed without error 00% 12639 - # 6 Short offline Completed without error 00% 12638 - # 7 Short offline Completed without error 00% 12637 - # 8 Short offline Completed without error 00% 12636 - # 9 Short offline Completed without error 00% 12635 - #10 Short offline Completed without error 00% 12634 - #11 Short offline Completed without error 00% 12633 - #12 Short offline Completed without error 00% 12632 - #13 Short offline Completed without error 00% 12632 - #14 Short offline Completed without error 00% 12631 - #15 Short offline Completed without error 00% 12630 - #16 Short offline Completed without error 00% 12629 - #17 Short offline Completed without error 00% 12628 - #18 Short offline Completed without error 00% 12627 - #19 Short offline Completed without error 00% 12626 - #20 Short offline Completed without error 00% 12625 - #21 Short offline Completed without error 00% 12623 - Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Completed [00% left] (0-65535) 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
=== START OF INFORMATION SECTION === Model Family: SAMSUNG SpinPoint F4 EG (AFT) Device Model: SAMSUNG HD204UI Serial Number: S2H7J1AZC07243 LU WWN Device Id: 5 0024e9 0047bb521 Firmware Version: 1AQ10001 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 6 Local Time is: Mon Sep 2 15:33:54 2013 CDT ==> WARNING: Using smartmontools or hdparm with this drive may result in data loss due to a firmware bug. ****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ****** Buggy and fixed firmware report same version number! See the following web pages for details: http://knowledge.seagate.com/articles/en_US/FAQ/223571en http://sourceforge.net/apps/trac/smartmontools/wiki/SamsungF4EGBadBlocks SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00)Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection:(20400) seconds. Offline data collection capabilities:(0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time:( 2) minutes. Extended self-test routine recommended polling time:( 340) minutes. SCT capabilities: (0x003f)SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 57 2 Throughput_Performance 0x0026 054 054 000 Old_age Always - 19190 3 Spin_Up_Time 0x0023 080 067 025 Pre-fail Always - 6275 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 902 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 12698 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 148 181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 2069 191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 1515 192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0 194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 35 (Min/Max 14/40) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 55 223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0 225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 205272 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 12698 - # 2 Extended offline Completed without error 00% 10656 - # 3 Short offline Completed without error 00% 10557 - # 4 Short offline Completed without error 00% 10556 - # 5 Short offline Completed without error 00% 10555 - # 6 Short offline Completed without error 00% 10554 - # 7 Short offline Completed without error 00% 10553 - # 8 Short offline Completed without error 00% 10552 - # 9 Short offline Completed without error 00% 10551 - #10 Short offline Completed without error 00% 10550 - #11 Short offline Completed without error 00% 10549 - #12 Short offline Completed without error 00% 10548 - #13 Short offline Completed without error 00% 10546 - #14 Short offline Completed without error 00% 10544 - #15 Short offline Completed without error 00% 10543 - #16 Short offline Completed without error 00% 10542 - #17 Short offline Completed without error 00% 10541 - #18 Short offline Completed without error 00% 10540 - #19 Short offline Completed without error 00% 10539 - #20 Short offline Completed without error 00% 10538 - #21 Short offline Completed without error 00% 10537 - Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Completed [00% left] (0-65535) 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
=== START OF INFORMATION SECTION === Device Model: WDC WD20EFRX-68AX9N0 Serial Number: WD-WMC301410292 LU WWN Device Id: 5 0014ee 6588844c9 Firmware Version: 80.00A80 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: Not in smartctl database [for details use: -P showall] ATA Version is: 8 ATA Standard is: ACS-2 (revision not indicated) Local Time is: Mon Sep 2 15:36:53 2013 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00)Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0)The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection:(26940) seconds. Offline data collection capabilities:(0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003)Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01)Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time:( 2) minutes. Extended self-test routine recommended polling time:( 272) minutes. Conveyance self-test routine recommended polling time:( 5) minutes. SCT capabilities: (0x70bd)SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 179 174 021 Pre-fail Always - 4033 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2138 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 10 194 Temperature_Celsius 0x0022 109 107 000 Old_age Always - 38 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 2138 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
