Help deciphering smartctl tests
Makaveli6103
Member
I have been have clicking issues for months and cannot figure out which hard drive it is. I ran some short smartctl tests. The results are blow. Also the last hard drive is a new WD Red I just installed last month.
Model Family: SAMSUNG SpinPoint F4 EG (AFT)
Device Model: SAMSUNG HD204UI
Serial Number: S2H7J1BZC16476
LU WWN Device Id: 5 0024e9 004824796
Firmware Version: 1AQ10001
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 6
Local Time is: Mon Sep 2 15:25:17 2013 CDT
==> WARNING: Using smartmontools or hdparm with this
drive may result in data loss due to a firmware bug.
****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ******
Buggy and fixed firmware report same version number!
See the following web pages for details:
http://knowledge.seagate.com/articles/en_US/FAQ/223571en
http://sourceforge.net/apps/trac/smartmontools/wiki/SamsungF4EGBadBlocks
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00)Offline data collection activity
was never started.
Self-test execution status: ( 0)The previous self-test routine completed
been run.
data collection:(19800) seconds.
capabilities:(0x5b) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities: (0x0003)Saves SMART data before entering
power-saving mode.
Error logging capability: (0x01)Error logging supported.
Short self-test routine
recommended polling time:( 2) minutes.
Extended self-test routine
recommended polling time:( 330) minutes.
SCT capabilities: (0x003f)SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 14
2 Throughput_Performance 0x0026 055 055 000 Old_age Always - 18266
3 Spin_Up_Time 0x0023 079 065 025 Pre-fail Always - 6442
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 860
5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0
8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 12646
10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 146
181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 2069
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 50
192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0
194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 34 (Min/Max 16/40)
195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 49
223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0
225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 203278
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 12646 -
# 2 Short offline Completed without error 00% 10598 -
# 3 Extended offline Completed without error 00% 10598 -
# 4 Short offline Completed without error 00% 10592 -
# 5 Short offline Completed without error 00% 10591 -
# 6 Short offline Completed without error 00% 10590 -
# 7 Short offline Completed without error 00% 10589 -
# 8 Short offline Completed without error 00% 10589 -
# 9 Short offline Completed without error 00% 10588 -
#10 Short offline Completed without error 00% 10587 -
#11 Short offline Completed without error 00% 10586 -
#12 Short offline Completed without error 00% 10585 -
#13 Short offline Completed without error 00% 10584 -
#14 Short offline Completed without error 00% 10583 -
#15 Short offline Completed without error 00% 10583 -
#16 Short offline Completed without error 00% 10581 -
#17 Short offline Completed without error 00% 10580 -
#18 Short offline Completed without error 00% 10579 -
#19 Short offline Completed without error 00% 10576 -
#20 Short offline Completed without error 00% 10575 -
#21 Short offline Completed without error 00% 10574 -
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
1 0 0 Completed [00% left] (0-65535)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: S2H7J1AZC17980
LU WWN Device Id: 5 0024e9 0048247a4
ATA Version is: 8
Local Time is: Mon Sep 2 15:30:53 2013 CDT
was never started.
been run.
data collection:(19980) seconds.
command.
power-saving mode.
recommended polling time:( 333) minutes.
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 6
2 Throughput_Performance 0x0026 055 055 000 Old_age Always - 18204
3 Spin_Up_Time 0x0023 080 066 025 Pre-fail Always - 6285
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1022
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 14690
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 186
181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 119384
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 123
194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 35 (Min/Max 15/40)
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 34
225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 207057
No Errors Logged
# 1 Short offline Completed without error 00% 14690 -
# 2 Extended offline Completed without error 00% 12647 -
# 3 Short offline Completed without error 00% 12641 -
# 4 Short offline Completed without error 00% 12640 -
# 5 Short offline Completed without error 00% 12639 -
# 6 Short offline Completed without error 00% 12638 -
# 7 Short offline Completed without error 00% 12637 -
# 8 Short offline Completed without error 00% 12636 -
# 9 Short offline Completed without error 00% 12635 -
#10 Short offline Completed without error 00% 12634 -
#11 Short offline Completed without error 00% 12633 -
#12 Short offline Completed without error 00% 12632 -
#13 Short offline Completed without error 00% 12632 -
#14 Short offline Completed without error 00% 12631 -
#15 Short offline Completed without error 00% 12630 -
#16 Short offline Completed without error 00% 12629 -
#17 Short offline Completed without error 00% 12628 -
#18 Short offline Completed without error 00% 12627 -
#19 Short offline Completed without error 00% 12626 -
#20 Short offline Completed without error 00% 12625 -
#21 Short offline Completed without error 00% 12623 -
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: S2H7J1AZC07243
LU WWN Device Id: 5 0024e9 0047bb521
ATA Version is: 8
Local Time is: Mon Sep 2 15:33:54 2013 CDT
was never started.
been run.
data collection:(20400) seconds.
command.
power-saving mode.
recommended polling time:( 340) minutes.
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 57
2 Throughput_Performance 0x0026 054 054 000 Old_age Always - 19190
3 Spin_Up_Time 0x0023 080 067 025 Pre-fail Always - 6275
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 902
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 12698
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 148
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 1515
194 Temperature_Celsius 0x0002 064 060 000 Old_age Always - 35 (Min/Max 14/40)
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 55
225 Load_Cycle_Count 0x0032 080 080 000 Old_age Always - 205272
No Errors Logged
# 1 Short offline Completed without error 00% 12698 -
# 2 Extended offline Completed without error 00% 10656 -
# 3 Short offline Completed without error 00% 10557 -
# 4 Short offline Completed without error 00% 10556 -
# 5 Short offline Completed without error 00% 10555 -
# 6 Short offline Completed without error 00% 10554 -
# 7 Short offline Completed without error 00% 10553 -
# 8 Short offline Completed without error 00% 10552 -
# 9 Short offline Completed without error 00% 10551 -
#10 Short offline Completed without error 00% 10550 -
#11 Short offline Completed without error 00% 10549 -
#12 Short offline Completed without error 00% 10548 -
#13 Short offline Completed without error 00% 10546 -
#14 Short offline Completed without error 00% 10544 -
#15 Short offline Completed without error 00% 10543 -
#16 Short offline Completed without error 00% 10542 -
#17 Short offline Completed without error 00% 10541 -
#18 Short offline Completed without error 00% 10540 -
#19 Short offline Completed without error 00% 10539 -
#20 Short offline Completed without error 00% 10538 -
#21 Short offline Completed without error 00% 10537 -
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Device Model: WDC WD20EFRX-68AX9N0
Serial Number: WD-WMC301410292
LU WWN Device Id: 5 0014ee 6588844c9
Firmware Version: 80.00A80
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ACS-2 (revision not indicated)
Local Time is: Mon Sep 2 15:36:53 2013 CDT
was never started.
been run.
data collection:(26940) seconds.
capabilities:(0x7b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time:( 272) minutes.
Conveyance self-test routine
recommended polling time:( 5) minutes.
SCT capabilities: (0x70bd)SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 174 021 Pre-fail Always - 4033
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2138
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 10
194 Temperature_Celsius 0x0022 109 107 000 Old_age Always - 38
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 2138 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
survive
Behold the Wumpus
Hi Makaveli6103,
If the clicking is constant\predictable and you can get at the drives when the system is on you can use a chopstick to make a crude stethoscope and check each drive. Just press one end of the chopstick against that little tab of skin next to the ear canal and the other against each drive. You should hear the clicking load & clear when you listen to the dodgy drive.
-Will
My bet is it is your Samsung drives. Their load cycle count is over 200k. They are probably loading and unloading. I know Western Digitals probably have a slightly different technical definition for "load cycle", but they do make some noise when they go in and out of the intellipark mode. You even properly applied the wdidle tool to your WD hard drive!
The SMART data does look fine though. I have no reason to think that any drives are failing. I'm not familiar with Samsung hard drives, but you may want to look into if/how to stop the load cycling though. I know WDs are only "rated" for 250k, so you are already most of the way there(if they were WDs).
gpsguy
Active Member
Do a Google search for "HD204UI 1AQ10001" regarding your Samsung's.
Your smtartctl runs, also display the message below. I saw it mentioned, while looking at some of the results from the search above.
Dusan
Neophyte Sage
You can also try smartctl -x, it returns more data than smartctl -a.
Makaveli6103
Member
Ok I will post -x also. But I am currently transferring 30GB of data to the server and the clicking pretty much stopped. Why is that?
Makaveli6103
Member
Can I update the firmware without data loss?
