Help dealing with error in daily output email
NASbox
Hi
Can someone please tell me if there is a way to answer the following questions
(Details follow the questions for ease of reading):
1. Have I sustained permanent data loss?
2. If yes, how can I determine which file(s) are damaged?
3. Are there any actions/tests I should run as a follow up.
I have a cron job dump the smart on all four drives in ZPOOL every night, and I don't see anything abnormal.
The reference URL given is useless.
Thanks in advance.
I am running the following version of FreeNas
FreeNAS Build	FreeNAS-8.0.4-RELEASE-p2-x64 (11367)
Platform	Intel(R) Pentium(R) CPU G620 @ 2.60GHz
Memory	16281MB
OS Version	FreeBSD 8.2-RELEASE-p7
and I got the following output
Removing stale files from /var/preserve:
Cleaning out old system announcements:
Backup passwd and group files:
Verifying group file syntax:
/etc/group is fine
Disk status:
Filesystem             Size    Used   Avail Capacity  Mounted on
/dev/ufs/FreeNASs2a    927M    379M    474M    44%    /
devfs                  1.0K    1.0K      0B   100%    /dev
/dev/md0               4.6M    1.9M    2.3M    44%    /etc
/dev/md1               824K    2.0K    756K     0%    /mnt
/dev/md2               149M     11M    126M     8%    /var
/dev/ufs/FreeNASs4      20M    979K     17M     5%    /data
TANK                   3.1T    2.6M    3.1T     0%    /mnt/TANK
Last dump(s) done (Dump '>' file systems):
Checking status of zfs pools:
  pool: TANK
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
	attempt was made to correct the error.  Applications are unaffected.
   see: http://www.sun.com/msg/ZFS-8000-9P
 scrub: scrub completed after 2h51m with 0 errors on Sun Sep  2 05:52:36 2012
	TANK        ONLINE       0     0     0
	  raidz2    ONLINE       0     0     0
	    ada0p2  ONLINE       0     0     1  64K repaired
	    ada1p2  ONLINE       0     0     1  64K repaired
	    ada2p2  ONLINE       0     0     0
	    ada3p2  ONLINE       0     0     0
errors: No known data errors
Checking status of ATA raid partitions:
Checking status of gmirror(8) devices:
Checking status of graid3(8) devices:
Checking status of gstripe(8) devices:
Network interface status:
Name    Mtu Network       Address              Ipkts Ierrs Idrop    Opkts Oerrs  Coll
re0    1500 <Link#1>      xx:xx:xx:xx:86:3b    65386     0     0    67260     0     0
re0    1500 192.x.x.x   ************          60959     -     -    66065     -     -
lo0   16384 <Link#2>                              19     0     0       19     0     0
lo0   16384 fe80:2::1     fe80:2::1                0     -     -        0     -     -
lo0   16384 localhost     ::1                      0     -     -        0     -     -
lo0   16384 your-net      localhost                0     -     -       19     -     -
Security check:
    (output mailed separately)
Scrubbing of zfs pools:
   skipping scrubbing of pool 'TANK':
      last scrubbing is 0 days ago, threshold is set to 35 days
Checking status of 3ware RAID controllers:
Alarms (most recent first):
  No new alarms.
-- End of daily output --
peterh
1/no
3/ zpool scrub and watch the result ,
it seems right now that both ada0 and ada1 has errors, you cannot replace both at the same time, you must decide
which one to replace first. The scrub might give a hint.
then replace fault disks, one at a time, allow to resilver before replace the second disc.
paleoN
1. It told you, "Applications are unaffected."
3. Check the smart info:
smartctl -a /dev/ada0
smartctl -a /dev/ada1
To test the drives:
smartctl -t long /dev/ada0
smartctl -t long /dev/ada1
Then check smart info again.
NASbox
Results of Tests - Does this look OK?
Thank you peterh and paleoN for your replies - does it look like I have any hardware problems?
I can't see anything obviously wrong. I'm wondering if the issue was caused by a connected
client machine crash.
Below are the results of all the tests I have run:
I ran a scrub, and got the following results:
freenas# zpool status
  pool: TANK
 state: ONLINE
 scrub: scrub completed after 2h51m with 0 errors on Tue Sep  4 06:23:25 2012
        TANK        ONLINE       0     0     0
          raidz2    ONLINE       0     0     0
            ada0p2  ONLINE       0     0     0
            ada1p2  ONLINE       0     0     0
            ada2p2  ONLINE       0     0     0
            ada3p2  ONLINE       0     0     0
I ran smartctl -t long /dev/ada0 and smartctl -t long /dev/ada1
Test Results for /dev/ada0
freenas# smartctl -a /dev/ada0
smartctl 5.41 2011-06-09 r3365 [FreeBSD 8.2-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model:     ST3000DM001-9YN166
Serial Number:    Z1F0DEKD
LU WWN Device Id: 5 000c50 03f6f0f48
Firmware Version: CC9C
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Thu Sep  6 18:38:01 2012 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  575) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 255) minutes.
Conveyance self-test routine
SCT capabilities:              (0x3081) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   118   100   006    Pre-fail  Always       -       168238624
  3 Spin_Up_Time            0x0003   092   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       494
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   069   060   030    Pre-fail  Always       -       10020923
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15333
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       70
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   074   052   045    Old_age   Always       -       26 (Min/Max 23/41)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       47
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       730
194 Temperature_Celsius     0x0022   026   048   000    Old_age   Always       -       26 (0 22 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       81518479278531
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       16938743448480
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       16380447340997
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     15326         -
# 2  Extended offline    Completed without error       00%        13         -
# 3  Conveyance offline  Completed without error       00%         5         -
# 4  Extended offline    Completed without error       00%         5         -
Test Results for /dev/ada1
freenas# smartctl -a /dev/ada1
Serial Number:    S1F032N3
LU WWN Device Id: 5 000c50 04a1e3765
Firmware Version: CC4C
ATA Version is:   8
Local Time is:    Fri Sep  7 02:37:18 2012 EDT
                                        been run.
data collection:                (  584) seconds.
                                        command.
                                        power-saving mode.
SCT capabilities:              (0x3085) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   117   100   006    Pre-fail  Always       -       156010016
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       410
  7 Seek_Error_Rate         0x000f   070   060   030    Pre-fail  Always       -       12269012
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15294
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       43
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   068   047   045    Old_age   Always       -       32 (Min/Max 23/41)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       22
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       797
194 Temperature_Celsius     0x0022   032   053   000    Old_age   Always       -       32 (0 23 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       261692357345777
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       16934379848544
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       5472283561213
No Errors Logged
# 1  Extended offline    Completed without error       00%     15291         -
# 2  Extended offline    Completed without error       00%         8         -
# 3  Short offline       Completed without error       00%         2         -
# 4  Conveyance offline  Completed without error       00%         1         -
Is there anything that I'm missing, or am I correct in assuming that I don't have
a serious hardware problem (assuming I don't see another reoccurance of this
problem)?
Thanks in advance for your input.
What you probably have is hard disk starting to have bad sectors or some other minor issue. You should continue to do your scrubs regularly and see if the amount of data that needs repairs on each scrub starts increasing. If it starts increasing rapidly you should replace that disk. Otherwise its nothing big to worry about.
Your data is still save as long as you don't have 3 disks that have problems in the same sectors at the same time. It's pretty unlikely to say the least. If you start having files corrupted when you do a # zpool status it will list some files and recommend you restore those from backup.
paleoN
It looks fine to me as well.
As you can see from the results, no bad sectors. Unless you meant it was a transient problem and it failed to read the sector earlier which is quite possible.
Like noobsauce80 said, keep an eye on your scrubs. You should have a regular schedule for smart tests for all your drives.
Thanks very much for the input noobsauce80 & paleoN.
No further data issues, but is it likely that this might have something to do with it?
http://forums.freenas.org/showthrea...-Help-Determining-the-Cause&p=37296#post37296
I'd also appreciate guidance as to what automatic tests I should configure.
Thanks. :confused:
I don't think that thread is related. I'd just do weekly scrubs of your zpool(s) and see what happens to the errors. Enable SMART if it isn't already and perhaps do a short test every 30 mins.
