Hi all It appears my flash drive maybe to small to old the update
Request Method: POST
Request URL: http://192.168.1.11/system/update/apply/?uuid=b4a51d778c0641e28c83cfce60a1e64d
Software Version: FreeNAS-11.0-RELEASE (a2dc21583)
Exception Type: MiddlewareError
Exception Value:
[MiddlewareError: b"'Insufficent space to install update'"]
Exception Location: ./freenasUI/system/views.py in update_apply, line 1247
Server time: Sat, 8 Jul 2017 09:13:50 -0700
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
39. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/system/views.py" in update_apply
1247. raise MiddlewareError(handler.error)
Exception Type: MiddlewareError at /system/update/apply/
Exception Value: [MiddlewareError: b"'Insufficent space to install update'"]
Request information
GET
Variable Value
uuid 'b4a51d778c0641e28c83cfce60a1e64d'
POST
Its a 16gb thumbdrive shouldn't that be suffient? Are there files I can delete to make room? If not how do I go about transferring everything to a new card.
Thanks in advance
Josh
Exception Value:
Traceback
Environment:
Traceback:
Request information
GET
Variable Value
POST
Thanks in advance
Josh
