Has anyone installed Hass.io onto Scale in docker?
oumpa31
Home assistant from Truecharts runs great but it is the Core version lacking the ability to have Add-ons and Supervisor. I have been looking for a solid week trying to find a write up or anything on how to install it and none of the writeups are valid anymore. An add-on to get cheap Temp sensors I can't use. Any help would be appreciated even if it means I need to create a VM to run it.
For now, just create a VM and run Hass-os on it.
oumpa31
I'm guessing I need the X86 version. but when I download it, it is a .img.xz image how would I go about using that image.
Generally you're probably better to use the VirtualBox image if you're going to do that:
With that .vdi file (you may need to unzip it with a tool like 7z) you can then write it into a sparse zvol with dd, then point your VM at that zvol as it's boot drive.
dd if=/mnt/tank/downloads/hassio.vdi of=/dev/zvol/SSDVM/VM/HassIO bs=1024k (edit paths to suit)
tprelog
There is a thread in the Home Assistant forum -- It was intended for VM on CORE but it may still be helpful
Which reminds me we're working with scale here and I should have suggested KVM instead of VirtualBox. The rest of what I said still works though.
oumpa31
I was able to get it copied to the ZVol but when I start it up nothing happens when i look at it in VNC it gets stuck on the Black screen wont run page
if you type exit at the prompt do you get the BIOS settings?
ClassicGOD
  1. Create VM: UEFI Boot Method and at least 32GB drive are required. I suggest VirtIO for HDD and NIC. Don't boot it yet.
  2. From shell as root:
    1. cd to a directory you can safely write to
    2. wget https://github.com/home-assistant/operating-system/releases/download/6.6/haos_ova-6.6.qcow2.xz
    3. unxz haos_ova-6.6.qcow2.xz
    4. qemu-img convert -O raw haos_ova-6.6.qcow2 /dev/zvol/your_pool/path/to/your/vm/zvol/haos-zvol
    5. wait few minutes until last command finishes
  3. Boot the vm
  4. Enjoy your new HA instalation.
oumpa31
  1. Create VM: UEFI and at least 32GB drive are required. I suggest VirtIO for HDD and NIC. Don't boot it yet.
  3. Boot the vm
ok ill try that now
ClassicGOD
ok ill try that now
Let us know if it works, I tested it on test VM before posting but I never know if instructions I write are easy to follow or if they make sens only in my mind.
I completely forgot the convert image step.
oumpa31
it loaded up and everything but it cant seam to save anything and it wouldn't find my location
ClassicGOD
Detecting localization depends on your browser so it should be unrelated to the VM itself but the saving thing is strange. What exactly are you trying to do that is not saving?
I have HAOS VM created using those instructions but I'm not using it right now as I will be transferring my HA installation to it when I transfer everything to my new NAS. But I quickly jumped into it and I'm able to log in, edit and save dashboards and it found my localization. All changes survived complete VM shutdown. So everything seems to be saving. Does your HAOS VM have internet access?
oumpa31
I think it was only having issues saving the initial Setup stuff. It seams to have saved everything I had to reset up coming from core. It has internet access I was able to connect to my Tuya account.
