Dear folks,
I'm new to this place but I've read a lot and a lot before posting. As you can read from the title, I'm planing to run FreeNas in a virtual environment and before you ask, YES I've read both topics which address this in detail, YES I've read it very carefully and YES I'm fully aware of the risks it comes along with. Nevertheless I've decided myself to take that approach for several reasons!
I want to build a box that is able to host...
- FreeNas VM (HDD via PCI Passthrough and fs=ZFS in RAIDZ2)
- Ubuntu or CentOS VM (with DNS, DHCP, OpenLDAP, and eventually serve as a VPN-Gateway)
- Ubuntu VM with (Apache + XBMC)
At the hypervisor level I wanted to test a new approach and use KVM and OpenBSD with pf as a basic Firewall (one or two VM might be later exposed in a DMZ). If it won't run properly I would go back to ESXi after I tried XEN.
Right now I'm at the point of selecting hardware components for that system and therefore I'm asking you guys for help, opinions, recommendations & hints!!!
I was planning to use the following hardware:
Case:
CPU:
Memory:
By the way, yes I want to build a Mini-ITX system and eventually encrypt the drives. Budget is around 1000-€!
Thank you very much in advance for your opinions and help...
Greets Sebastian
Case:
- Fractal Design Gehäuse Node 304
- ASRock E3C226D2I 2xGL/SATA600/USB3.0/VGA/Seriell Mini-ITX Sockel 1150
CPU:
- Intel® Xeon® Processor E3-1220L v2 or Intel® Xeon® Processor E3-1240L v3
Memory:
- 16GB Kingston ValueRAM DDR3-1600 regECC DIMM CL11 Single (reg or without reg?)
- EKL Alpenföhn Sella Tower Kühler (looked nice and has 4 pins)
- 350 Watt be quiet! System Power 7 Bulk Non-Modular 80+ Bronze (here I'm not sure what to take)
- 6x 3TB Western Digital Red (5 for RAIDZ2)
Greets Sebastian
