Loading kernels i3 6100
Mr.Turkey
hello! I've been seeing this problem a lot on other forms but nothing saying a fix or anything.
I have a i3 6100 as you read above and my motherboard is the
ASRock - H270M-ITX/ac Mini ITX LGA1151 Motherboard I don't see why it won't work with FreeNAS.
I'm booting off of USB (yes I'm using two USB's lol) using "win32diskimager" to write the ISO to the USB and I'm using FreeNAS-9.10.2-U3 I got right from the site. Any ideas on what I'm doing wrong?
I also read that USB 2.0 has to be in a 2.0 slot not just any slot which is taken care of and still nothing. I've reformatted my USB's countless times now lol.
Any help and I will be grateful.
Dice
Mr.Turkey
You're not providing a clear description of the problem?
I'm sorry, should start proof reading a bit more. After I install the base os. I reboot remove the installation Media. It goes through the whole process again to it basically stop's at loading kernels. I have no clue how to get past it
Dice
What's the error message?
Reply in [code ][/code ] tags.
