Ok, I'm building my first freenas box. This is for home use. I will be backing up half a dozen computers. I plan to store a lot of media and have a plex server serving 2-3 screens at a time. It will host multiple VM's and provide block storage for several more. I also plan to use it to PXE boot.
The one thing I'm really not sure about is the case. I think it only supports SAS1. Unfortunately, I've already bought the case - before I did sufficient research. Also, I'm not sure how the SAS cable works or if I need accessories to go with it. Will it plug straight into this motherboard without having to buy additional cables or M1015 cards?
I plan to put all the drives in straight raid-1 mirrors. For several reasons,
Thanks for any advice you might offer.
motherboard: X9SRH-7F $389.99
http://www.superbiiz.com/detail.php?p=MB-X9SRHB&c=fr&hash=6838dvEiam3Zw4B6qdWb5jteqrv1zOKM8uN+5Pw1CdZqnODDVkp5qbuQjhI8D8GTc/2xnTEs3hXu+PfAkkNpjIMVqxFBFb1nK2YXURnpeiXM+mzUdu08PAy0be/310TfZS75NZKlDPsDTe5A&gclid=CjwKEAjw86e4BRCnzuWGlpjLoUcSJACaHG55MEcHU2uBlqE-wdlScU7hzOPOLShvnPVmrpl6yFBoVRoCFyHw_wcB
cpu: E5-1620v2 $343.94
http://www.amazon.com/dp/CM80635012/?tag=ozlp-20
memory: 2 x 16GB 1866MHz ECC Reg 2Rx4 Samsung M393B2G70QH0-CMA Memory SuperMicro MEM-DR316L-SL02-ER18
http://www.memoryamerica.com/16gb-pc3-14900-ddr3-1866mhz-ecc-registered-cl13-240-pin-dual-rank-m393b2g70qh0-cma-samsung-dimm-memo.html?utm_source=16gb-pc3-14900-ddr3-1866mhz-ecc-registered-cl13-240-pin-dual-rank-m393b2g70qh0-cma-samsung-dimm-memo&utm_medium=shopping+engine&utm_campaign=googleproducts&gclid=CjwKEAjw86e4BRCnzuWGlpjLoUcSJACaHG55YA27KXDgn94mVAVpQt3qplLekhCEuIpnOCiPhV_x1xoCoMfw_wcB
Case: 4U Supermicro 24 bays Storage Server Chassis SC846E1-R900B 846EL1 SAS Expander
http://www.ebay.com/itm/SUPERMICRO-...H-24x-TRAYS-/171527440510?hash=item27efd5087e
Drives: WD Red Pro 4TB NAS Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD4001FFSX $211 x 6-8
http://www.amazon.com/Red-Pro-Hard-Disk-Drive/dp/B00LO3KRM8/ref=sr_1_4?s=pc&ie=UTF8&qid=1460337363&sr=1-4&keywords=western+digital+red&refinements=p_n_feature_keywords_four_browse-bin:8067154011
- performance - mirrors offer the best performance. Period. :)
- flexibility - mirrors can be split if needed
- easy expandability - you only have to buy 2 drives at a time to expand the pool
