hangs at "starting cron" over USB, 8.3 beta4
carl0s
PowerEdge 2900.
When installed onto USB stick (PNY 8gb), startup hangs at "starting cron".
Any ideas?
William Grzybowski
Press CTRL+T to give you the stuck process (and pass it here)... And then CTRL+C to kill it, as a workaround.
carl0s
Thanks William. I came back upstairs, and it seems to have started! Perhaps the USB stick is just very slow to boot up.
