So got the update pkg's and bash, nano are installed and updated.. so able to get to step 10 and not working..
Just now stuck at the openvpn, clean install.. step 10
Fri Jan 15 21:26:17 2016 OpenVPN 2.3.10 amd64-portbld-freebsd9.2 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Jan 15 2016
Fri Jan 15 21:26:17 2016 library versions: OpenSSL 0.9.8y 5 Feb 2013, LZO 2.09
Fri Jan 15 21:26:17 2016 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Jan 15 21:26:17 2016 WARNING: file 'sample-keys/client.key' is group or others accessible
Fri Jan 15 21:26:17 2016 Socket Buffers: R=[42080->42080] S=[9216->9216]
Fri Jan 15 21:26:17 2016 UDPv6 link local (bound): [AF_INET6]::1:16101
Fri Jan 15 21:26:17 2016 UDPv6 link remote: [AF_INET6]::1:16100
Fri Jan 15 21:26:17 2016 Diffie-Hellman initialized with 2048 bit key
Fri Jan 15 21:26:17 2016 WARNING: file 'sample-keys/server.key' is group or others accessible
Fri Jan 15 21:27:17 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Jan 15 21:27:17 2016 TLS Error: TLS handshake failed
Fri Jan 15 21:27:17 2016 Closing TUN/TAP interface
Fri Jan 15 21:27:17 2016 /sbin/ifconfig null destroy
ifconfig: interface null does not exist
Fri Jan 15 21:27:17 2016 FreeBSD 'destroy tun interface' failed (non-critical): external program exited with error status: 1
Fri Jan 15 21:27:17 2016 ../tests/t_cltsrv-down.sh null 1500 1541 init
Fri Jan 15 21:27:17 2016 SIGTERM[soft,tls-error] received, process exiting
FAIL: t_cltsrv.sh
1 of 2 tests failed
(1 test was not run)
Please report to
openvpn-users@lists.sourceforge.net
*** [check-TESTS] Error code 1
1 error
*** [check-am] Error code 2
1 error
*** [check-recursive] Error code 1
1 error
*** [check] Error code 2
1 error
*** [post-build] Error code 2
Stop in /usr/ports/security/openvpn.
*** [install] Error code 1
