GUIDE: Setting up Transmission with OpenVPN and PIA
thijsjek
I had pia/openvpn running on my transmission jail (freenas 11) and everything worked correctly. Later i noticed that transmission was wonky and did a reinstall of the plugin.
I installed openvpn like in the start thread by myself, and now: service openvpn start, doens't start actually.
tail /var/log/messages
Sep 10 13:13:51 transmission_1 openvpn[76796]: TCP/UDP: Preserving recently used remote address: [AF_INET]46.166.186.234:1198
Sep 10 13:13:51 transmission_1 openvpn[76796]: UDP link local: (not bound)
Sep 10 13:13:51 transmission_1 openvpn[76796]: UDP link remote: [AF_INET]46.166.186.234:1198
Sep 10 13:13:51 transmission_1 openvpn[76796]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache opt
ion to prevent this
Sep 10 13:13:51 transmission_1 openvpn[76796]: [296a267602ebc4b8d1ec2f525b433900] Peer Connection Initiated with [AF_INET]46.166.186
.234:1198
Sep 10 13:13:57 transmission_1 openvpn[76796]: TUN/TAP device /dev/tun0 opened
Sep 10 13:13:57 transmission_1 openvpn[76796]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Sep 10 13:13:57 transmission_1 openvpn[76796]: /sbin/ifconfig tun0 10.61.10.6 10.61.10.5 mtu 1500 netmask 255.255.255.255 up
Sep 10 13:13:57 transmission_1 openvpn[76796]: FreeBSD ifconfig failed: external program exited with error status: 1
Sep 10 13:13:57 transmission_1 openvpn[76796]: Exiting due to fatal error
ifconfig -a
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
		groups: lo
epair5b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=8<VLAN_MTU>
		ether 72:28:d2:03:a3:ed
		inet 192.168.178.44 netmask 0xffffff00 broadcast 192.168.178.255
		status: active
		groups: epair
How can i solve this?
EDIT: After a reboot of the server, not just jail, all problems are solved
indivision
When there is connection instability, transmission will switch off of the VPN connection and start using the server IP. The potential for that to happen at unpredictable times pretty much defeats the purpose of using VPN and may be giving people a false sense of security. There should at least be a disclaimer in the OP about this.
That said, is there a guide or second script for blocking all connections except through the VPN? I have found a few guides in other posts. But, they didn't work. They appear to be either outdated or meant for different variations of installing openvpn (different filenames, folders, etc.).
Amsoil_Jim
is anyone have any issues with the port-forward script? I keep getting and unauthorized user error.
Loading port forward assignment information..
{"port":32579}
Unexpected response: <h1>401: Unauthorized</h1>Unauthorized User
lkh5650
So my transmission was working well with PIA and now my listening ports are closed even with the enable port forwarding checked on transmission. I found this "https://forums.freenas.org/index.ph...rt-closed-on-transmission-with-pia-vpn.27628/" and that person claimed that your script solved the problem!! I am however not sure on how/what to do with your script. Am I supposed to make a new file? or add this in current openvpn.conf file..? little bit of direction would be really appreciated!
I am interested in using the port forward feature of PIA. I hacked together this script starting from the PIA script, and it seems to work (forwards port to Transmission). I am still learning FreeNAS and scripting so if anyone has a more elegant solution I would be interested.
(this runs inside the jail with OpenVPN and Transmission)
#! /usr/local/bin/bash
# Enable port forwarding
# Requirements:
#   your Private Internet Access user and password as arguments
# Usage:
#  ./port_forward.sh <user> <password>
error( )
  echo "$@" 1>&2
  exit 1
error_and_usage( )
  echo "$@" 1>&2
  usage_and_exit 1
usage( )
  echo "Usage: `dirname $0`/$PROGRAM <user> <password>"
usage_and_exit( )
  usage
  exit $1
version( )
  echo "$PROGRAM version $VERSION"
port_forward_assignment( )
  echo 'Loading port forward assignment information..'
  if [ "$(uname)" == "Linux" ]; then
	local_ip=`ifconfig tun0|grep -oE "inet addr: *10\.[0-9]+\.[0-9]+\.[0-9]+"|tr -d "a-z :"|tee /tmp/vpn_ip`
	client_id=`head -n 100 /dev/urandom | md5sum | tr -d " -"`
  fi
  if [ "$(uname)" == "FreeBSD" ]; then
	local_ip=`ifconfig tun0 | grep "inet " | cut -d\  -f2|tee /tmp/vpn_ip`
	client_id=`head -n 100 /dev/urandom | md5 -r | tr -d " -"`
  fi
  json=`wget --no-check-certificate -q --post-data="user=$USER&pass=$PASSWORD&client_id=$client_id&local_ip=$local_ip" -O - 'https://www.privateinternetaccess.com/vpninfo/port_forward_assignment' | head -1`
  echo $json
  PORTNUM=`echo $json | grep -oE "[0-9]+"`
EXITCODE=0
PROGRAM=`basename $0`
VERSION=1.0
USER=$1
PASSWORD=$2
while test $# -lt 2
do
  case $1 in
  --usage | --help | -h )
	usage_and_exit 0
  --version | -v )
	version
	exit 0
	error_and_usage "Unrecognized option: $1"
  esac
  shift
done
transmission-remote -p $PORTNUM
exit 0
Baenwort
If you haven't found this yet there is a guide to setting up a monitoring script that shuts down the jail's internet connection when the PIA openVPN connection fails. https://forums.freenas.org/index.ph...ith-openvpn-and-pia.24566/page-20#post-341622 I don't know for certain if it will work but it reads like it should.
lkh5650
lkh5650
after many many hours of trials and errors, i got the port forwarding to work but only manually when i do
./port_forward.sh
is there anyway that i can have the port_forward.sh to be performed when transmission starts?
Rikkard
I use ipfw. Then a configfile, mine look:
add 01000 allow log udp from 192.168.1.0/24 to 8.8.8.8 dst-port 53 keep-state
add 01008 allow ip from 192.168.1.0/24 to 192.168.1.0/24 keep-state
add 02000 allow ip from 192.168.1.0/24 to 185.213.152.131 keep-state
add 02002 allow ip from 192.168.1.0/24 to 185.213.152.132 keep-state
add 02004 allow ip from 192.168.1.0/24 to 185.213.152.134 keep-state
add 04000 allow ip from 127.0.0.1 to any
add 05004 allow ip from 10.15.0.0/16 to any
add 05006 allow ip from any to 10.15.0.0/16
add 65534 deny ip from any to any
Michael Sparks
Any idea why the script is no longer working?
jls
jexec [JAILID] tcsh
cd /tmp
wget --quiet --no-check-certificate -O pia.sh https://gist.githubusercontent.com/jed-frey/6d475dcc34c710f62a7c/raw/fcf18484225b0676fe0c556e7798cc08cdc7a631/pia.sh
chmod +x pia.sh
./pia.sh
Starting openvpn.
Waiting 10 seconds for OpenVPN to spin up
If these are different, OpenVPN is working
Old IP: 72.234.183.208
New IP: 72.234.183.208
Not a big issue was able to complete using update cli in first post. Thanks
cloud
I have both ipfw and openvpn running and they appear to be working correctly
I'm getting a 403 forbidden error from the WEB GUI when I try to access it from my LAN.
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
I'm using the same ipfw rules as listed, even when I turn off the firewall and flush the rules.
I wasn't using the RPC whitelist before so nothing should have changed.
How/Where can I allow or whitelist my LAN network?
goerz
I successfully installed openvpn on my transmission jail on FreeNAS-9.10.2-U6. I also set up the internal firewall so that transmission does not connect if the vpn is down. I read that PIA has changed the port forwarding procedure, so the port forwarding scripts posted in this thread don't work anymore (https://www.privateinternetaccess.com/forum/discussion/23431/new-pia-port-forwarding-api).
Although I am no computer expert, I managed to make this script to work. It does not need your PIA username and password, but it needs your transmission credentials.
#!/usr/bin/env bash
# Enable port forwarding when using Private Internet Access
# install curl first (pkg install curl)
# Usage:
#  ./port_forwarding.sh
TRANSUSER=your_transmission_username
TRANSPASS=your_transmission_password
TRANSHOST=localhost
error( )
  echo "$@" 1>&2
  exit 1
error_and_usage( )
  echo "$@" 1>&2
  usage_and_exit 1
usage( )
  echo "Usage: `dirname $0`/$PROGRAM"
usage_and_exit( )
  usage
  exit $1
version( )
  echo 'Loading port forward assignment information...'
	client_id=`head -n 100 /dev/urandom | sha256sum | tr -d " -"`
  fi
	   client_id=`head -n 100 /dev/urandom | shasum -a 256 | tr -d " -"`
  fi
  json=`curl "http://209.222.18.222:2000/?client_id=$client_id" 2>/dev/null`
  if [ "$json" == "" ]; then
	echo Port forwarding is already activated on this connection, has expired, or you are not connected to a PIA region that supports port forwarding
	exit 0
  fi
  echo server returned $json
   #trim VPN forwarded port from JSON
	PORT=$(echo $json | awk 'BEGIN{r=1;FS="[{}\":]+"} /port/{r=0; print $3} END{exit r}')
	echo if successful, trimmed port is:$PORT
	#change transmission port on the fly
	transmission-remote $TRANSHOST --auth $TRANSUSER:$TRANSPASS -p "$PORT"
	 echo remember to run no longer than 2 mins after reconnecting/connecting to vpn server.
EXITCODE=0
VERSION=2.1
while test $# -gt 0
do
  case $1 in
	usage_and_exit 0
  --version | -v )
	version
	exit 0
  esac
  shift
done
exit 0
However, this script must run within 2 minutes of the vpn connection, but openvpn should have time to connect before this script runs. So I would like this script to run 1 minute after openvpn connects at startup. How can I automate this task when I start the jail? What if the vpn disconnects and then it reconnects?
Thanks,
goerz
ChaosBlades
#!/usr/bin/env bash
# Usage:
TRANSHOST=localhost
error( )
  echo "$@" 1>&2
  exit 1
error_and_usage( )
  echo "$@" 1>&2
  usage_and_exit 1
usage( )
usage_and_exit( )
  usage
  exit $1
version( )
  fi
  fi
	exit 0
  fi
EXITCODE=0
VERSION=2.1
while test $# -gt 0
do
  case $1 in
	usage_and_exit 0
  --version | -v )
	version
	exit 0
  esac
  shift
done
exit 0
Thanks,
goerz
Reminder, port forwarding is only available on the following gateways or you will get the error "Port forwarding is already activated on this connection, has expired, or you are not connected to a PIA region that supports port forwarding".
  • CA Toronto
  • CA Montreal
  • CA Vancouver
  • Netherlands
  • Switzerland
  • Sweden
  • France
  • Germany
  • Romania
  • Israel
sam-wade
Hi Guys,
Just tried setting this up, everything works fine till the end of the first section, where I check my IP address. When I check it it displays back with my external IP address not with the vpn server one. Any help would be appreciated
dobbies
Hi jafrey
I just wanted to thank you for your now "quite ancient" post. I'm far from an expert on the FreeNAS system, but I've been trying to set up a PIA VPN in the transmission jail for days now without success. Most of the posts I've found on the forum have left me with nothing less than confusion. I don't know how I found your post but within an hour of reading it I had a PIA VPN up and running on my server. Thank You.
dobbies
Hi Guys,
Make sure you are checking your external IP from within your jail.
Example: root@transmission_??:/ # wget -qO - http://wtfismyip.com/text
If you use the same URL from your root you should see your normal IP.
Hope this helps?
Simplicity
I followed your guide and everything works. I failed at the Reddit steps #3/4 and I was wondering once I am setup how do you switch PIA servers? Can you write in your own words how to do the step 3/4 and changing the PIA server once configured?
denist
Hi Guys,
Just update my port_forward.sh script with the new API Port Forwarding from PIA.
#!/usr/local/bin/bash
# Cronable port forwarding script for PIA/transmission running on FreeNAS
# Requires bash, jq (JSON parser) and curl
# pkg install -y jq bash curl
# Export path for when you use this in cron
export PATH="/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/root/bin"
# echo date/time for logging
echo "Transmission Port Forward $(date +%Y-%m-%d-%H:%M:%S)"
get_new_port( )
  # Check if curl is installed
  if ! [ -x /usr/local/bin/curl ]; then
   echo "Curl not installed/not executable"
   exit 0
  fi
  # dynamically figure out the tunnel adapter name
  tunnel_adapter=`ifconfig | grep "tun" | cut -d ":" -f1`
  local_ip=$(ifconfig $tunnel_adapter | grep "inet " | cut -d\  -f2)
  #client_id seems to want sha256sum data
  client_id_file="/usr/local/etc/openvpn/pia_client_id"
  if [ ! -f "$client_id_file" ]; then
   if hash shasum 2>/dev/null; then
	   head -n 100 /dev/urandom | shasum -a 256 | tr -d " -" > "$client_id_file"
  elif hash sha256sum 2>/dev/null; then
	   head -n 100 /dev/urandom | sha256sum | tr -d " -" > "$client_id_file"
   else
	   echo "Please install shasum or sha256sum, and make sure it is visible in your \$PATH"
	   exit 1
   fi
  fi
  client_id=`cat "$client_id_file"`
  json=$(curl --interface $tunnel_adapter "http://209.222.18.222:2000/?client_id=$client_id" 2>/dev/null)
	json='Port forwarding is already activated on this connection, has expired, or you are not connected to a PIA region that supports port forwarding'
  fi
  port=$(echo $json | awk 'BEGIN{r=1;FS="{|:|}"} /port/{r=0; print $3} END{exit r}')
  # test to make sure that the port is actually a number
  if ! [[ $port =~ ^[0-9]+$ ]]; then
   echo $json
   exit 1
  fi
  transmission-remote -p $port
   echo $json
is_port_forwarded( ) {
  # -pt tests for open port.
  json=$(transmission-remote -pt)
  if [[ $json == "Port is open: No" ]]; then
   echo "Closed port detected"
  get_new_port
   elif [[ $json == "Port is open: Yes" ]]; then
   echo "Open port detected"
   exit 1
  fi
check_for_connectivity( ) {
  if nc -zw 1 google.com 80; then
  echo "VPN connection up"
  else
  echo "VPN connection down"
	exit 1
  fi
is_port_forwarded
exit 1
The i created the cronjob to run every 2 mins as follows.
*/2 * * * * /usr/local/bin/bash /sabnzbd/scripts/port_forward.sh >> /var/log/pia.log 2>&1
Since i am using the Kill Script there is no internet when the Server boots up. Openvpn starts but the ipfw rules are blocking internet access until the Kill script runs. I have this set on 5 min intervals and the port forward on 2 min intervals. This gives it enough time for the openvpn to start and ipfw to write the correct rules, then finally the port_forward script runs and creates the port forward in transmission. You do not require any usernames in my script which has been mashed up between a few scripts that i have found. Hope this helps someone else.
denist
Final Port script that work. Above there was an error.
get_new_port( )
   exit 1
  fi
  # client_id seems to want shasum/sha256sum data
   else
	   exit 1
   fi
  fi
  # port_forward_assignment
  fi
  # trim VPN forwarded port from JSON
   echo $json
   exit 1
  fi
   echo 'Port forward successful'
   echo $local_ip:$port
   exit 1
  get_new_port
   exit 1
  fi
  is_port_forwarded
  else
	exit 1
  fi
is_port_forwarded
exit 1
thijsjek
get_new_port( )
   exit 1
  fi
   else
	   exit 1
   fi
  fi
  fi
   echo $json
   exit 1
  fi
   exit 1
  get_new_port
   exit 1
  fi
  is_port_forwarded
  else
	exit 1
  fi
is_port_forwarded
exit 1
How can i put in the transmission password and username to authenticate with transmission?
denist
transmission-remote -n 'transmission:transmission' -p $port
