Can anyone direct me to a guide on how to expose NFS shares to Rancher OS in FreeNAS 11.2? The documentation for this (16.3.6. Configuring Persistent NFS-Shared Volumes) is thin and I'm still not able to get it to work. Thanks for any help.
I created a step by step guide on GitHub based on the youtube video: https://github.com/redshift-s/rancheros-docker-media
This guide includes how to install dockers with code templates included on the GitHub repo, so you dont have to do so much manual configuration in portainer.
This guide includes how to install dockers with code templates included on the GitHub repo, so you don't have to do so much manual configuration in portainer.
Setup RancherOS
This steps creates a VM with the OS "RancherOS", called "Docker Host" in FreeNAS
Virtual Machines
Add
Dropdown: Docker Host
Virtual CPUs: 2
Memory: 4096
Network: Select network on FreeNAS (re1)
Raw filename: rancheros
Raw filename password: rancher_password
Raw file location: /mnt/tank/vm/
DONE
Docker Host not available. How do you install successfully on 11.2+?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
