The top one is the volume, the one immediately inside is the all inclusive dataset that recent FreeNAS versions now display. The capacity numbers on the volume are raw storage before overhead, and the capacity numbers on the all inclusive dataset take overhead into account.But I am confused as to why the main ZFS volume is listed twice in the GUI as what appears to be a subset of itself, with two vastly different values for Used/Available space.
The top one is the pool itself.
Thanks for trying, but nothing about the way this information is presented is making any sense to me so far. The screenshot in the FreeNAS guide makes even less sense. I have no idea how you fit 22.8GiB inside of 2.2GiB and why the "all inclusive dataset" (just like on my screenshots) has less than half the apparent available capacity of the parent volume:The top one is the volume, the one immediately inside is the all inclusive dataset that recent FreeNAS versions now display. The capacity numbers on the volume are raw storage before overhead, and the capacity numbers on the all inclusive dataset take overhead into account.
In your earlier screenshots, the numbers basically make sense. Raw capacity for 8 120GB disks is naively 960GB, which is close enough to 390+482 when you realize that GiB != GB.
Then the pool capacity basically makes sense when you realize you've given up 3 drives-worth of space to RAIDZ3 overhead, leaving 600GB or about 585GiB, less the additional filesystem overhead.
But like you, I can't make sense of the latest screenshot you posted.
Where are you seeing this?But seriously, that's extremely obnoxious, that only the letters "T", "G", "M" or "K" are being used in place of proper units.
Strictly speaking, drive manufacturers have always used base-10. Some others have habitually used GB incorrectly to mean base-2, which is why disk sizes always look lower in Windows than they do in hard drive sales literature. Of course, we all tend to use GB incorrectly when referring to RAM, which has always been sized in base-2, and so should really be counted in GiB. In some languages (e.g. French) there's no confusion because they use clearly different abbreviations. At least, that's my understanding of all this. FreeNAS only recently started using the binary units.I can't possibly be the only uninformed user that automatically assumed that if anyone were to shorten units down to a single letter they would "obviously" be referring to the binary units that have been in use for decades and are still the primary units used to sell storage media, not these newfangled base-10 units that no one outside the geek world has ever heard of. I am very much not in favor of shortening units down to the point where they become ambiguous. Not cool. I don't get how anyone finds ambiguous units acceptable.
FreeNAS 10 will let you select your favorite units.OHHHHH, so when it says the "size" of my pool is "872G", that's actually gibibytes, not gigabytes? How incredibly obnoxious. But at least it makes much more sense that I'm only losing 22GiB (894 minus 872) to filesystem overhead to begin with, rather than 88GB. That's only like 2.5% instead of 10% capacity loss for formatting. I'm cool with that.
But seriously, that's extremely obnoxious, that only the letters "T", "G", "M" or "K" are being used in place of proper units. So I guess I have to assume that the "M" is mebibytes and the "K" is kibibytes also, and when I do go to larger disks and see a "T" it will stand for tebibytes. 'Cause if there were any unit mixing going on I'd hafta choke a bee-yotch.
But on the bright side, after a lot of fumbling around with Spotlight unit conversions and a calculator, you've totally transformed my understanding of what I'm seeing. Except 234GiB + 175GiB = 409GiB = 440GB which still falls pretty far short of the 559GB that the ServeTheHome RAID calculator says should be the "usable storage" on this array. Yes, I'm giving up three out of eight disks for parity, I get that, and there will always be a bit more loss for the actual filesystem formatting, but I seem to be losing more than 50% of the raw storage capacity in the end. There's another 160GB (150GiB) missing, that's more than an entire additional drive of space lost. Something about that doesn't jibe. If there's really that much additional "filesystem overhead" with RAID-Z3 I'll definitely have to go to an 11-disk array or this whole venture will simply be too expensive per gig^H^H^H gibibtye. Or, I'll have to live with 8 disks and RAID-Z2.
Thanks for the big push on the road to ZFS enlightenment. Still a long way to go.
Awesome!FreeNAS 10 will let you select your favorite units.
As for all the space you're 'losing', I think you would probably find that the percentage overhead would be lower with a larger pool.
You'll have to convince jkh to allow for arbitrary units.Wow, I can get my pool size reported in kiloquads?!?!? Awesome!!!!
Is a quad 32 bits or a nibble?
Yes, but for 8 disks, still only about 1/10th of what RedBear sees as 'missing'.With 120GB disks the 2GB swap partitions are significant, whatever kind of GB the latter are.
EDIT: you mean with the command-line ZFS tools?
Mystery solved, I think. You're all going to find this quite amusing, I'm sure. I kept looking around trying to figure out where one goes to verify the Z-level of a pool, then remembered I'd seen raidz-something in the output of zpool status:Yes, but for 8 disks, still only about 1/10th of what RedBear sees as 'missing'.
$ zpool status pool: TestVolume1 state: ONLINE scan: scrub repaired 0 in 0h49m with 0 errors on Mon Jun 1 04:34:27 2015 config: NAME STATE READ WRITE CKSUM TestVolume1 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/6fa5f02c-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/70dacffd-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/7229b9aa-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/7360c7f6-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 raidz2-1 ONLINE 0 0 0 gptid/75bf9b8e-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/770560dc-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/785205cf-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 gptid/798929be-0032-11e5-a439-6c0b8409b367.eli ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h0m with 0 errors on Tue Jun 2 04:47:44 2015 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/8c5d2aa0-fb71-11e4-a61f-001517b066a2 ONLINE 0 0 0 errors: No known data errors
:DIt's a good thing I'm playing in a disposable sandbox of tiny, cheap drives, because I am getting poop EVERYWHERE so far.
If you had, say, 3 120GB drives and 5 250GB drives, there would be 2 plus signs. One would invite you to begin the process of creating a 3-disk RAIDZ1 volume and the other would invite you to begin the process of creating a 5-disk RAIDZ2 volume. And if you clicked both, you would get a volume made of the 2 vdevs I just described. The idea would be that since ZFS behave as though all the drives in a vdev are the size, you would prefer to use them that way for efficiency.I remain confused about the exact purpose of the big plus button and why I could only click it once before it grayed out even though there are 8 drives, but at least I finally figured out how to set up and identify an 8-disk array correctly.
:D
No, seriously, congratulations. :)
The devs have struggled for a long time with how to make an understandable and accessible GUI for FreeNAS, and I think it is inherently very difficult to do something like this. It also shows the wisdom of taking some time to experiment and understand what you're doing before you just blindly start using the thing, which is, sadly, not exactly the idea behind an appliance device.
