Ghost username dataset being created by TN12, user home directory already exists.
Paul5
Confused as hell, TN12. I'll try and explain as best as I can.
Important my datasets are passphrase decrypted.
I have TN creating a Ghost username dataset called 'test' when I create a folder in the 'System' Dataset using W10 Network access. The actual 'test' folder exists and is a working home folder in this Truenas test setup. The other quirk is that if I login via ftp for the user I can still navigate up the tree.
|-Archive
System (DataSet)
test (DataSet) Created by Truenas when in W10 > network > System create a test folder. BUT it does not appear in windows, only in ftp.
|-Tank1 (DataSet)
|-test (user home folder) Login via ftp and straight to home folder. However I can still navigate up the tree.
Paul5
Without going into it. It seems that the home folders have to be datasets and not just any folder.
