if_<name of driver minus .ko>_load="YES" and then rebooting to activate. Please don't use USB network interfaces with TrueNAS, as these drivers aren't tested for reliability, and the Ethernet dongle will likely overheat.A little orthogonal to your question here, but both this post and your other one (on expanding your RAID array) strongly suggest that you've put TrueNAS into production with minimal understanding of its requirements and how it works. For the sake of your data, please try to correct that. The documentation (link at the top of the page) would be a good place to start. The hardware recommendations guide would be good as well. It's getting a little dated, but Uncle Fester's guide (link in my .sig) also has a lot of good information.Motherboard - x370 Gaming pro carbon
should I then go for PCIe ethernet Card?USB Ethernet is a trainwreck (the Realtek ones are somewhere between "Realtek PCIe NIC" and "SATA port multiplier" in how awful they are).
what about smb3.0 multi?LACP requires the use of a managed switch that knows how to speak LACP. Otherwise, your practical choice is limited to doing failover with LAGG.
Official multi-channel support won’t arrive until TrueNAS 13.what about smb3.0 multi?
I wish I could, hard to find a cheap one here.Realtek are crap - use an Intel
How failover works? does it increase bandwidth? isn't it for, if a NIC fails, it continuesOfficial multi-channel support won’t arrive until TrueNAS 13.
I feel like You guys are way too rude about the hardware. Not everyone's born with a silver spoon nor every country's earning is the same. In my country the least salary is below 100USD... I don't earn much through my new start up... So kindly don't give the crap about EXPENSIVE hardware... Truenas was about to make the old computer into nas. I could have bought UNRAID maybe? But I didn't expect this forum to be that rude!!! Sorry but not sorry~!!!Not to put too fine a point on it, but "proper hardware is too expensive" won't make TrueNAS magically work well with crap hardware.
What about RAIDZ1 with 4x4tb and 2xGbps into LACP and windows will I get 2Gbps bandwidth? NIC teaming on windows 10 too.But, then again, for a single client, neither does LACP.
