Setup USB LAN RTL8153 visible as ThinkPad USB3.0 LAN
kondisz
I have a problem with the installation ThinkPad USB3.0 LAN. This USB network adapter based on RTL8153:
ugen1.5: <Lenovo Thinkpad USB LAN> at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=ON (180mA)
  bLength = 0x0012
  bDescriptorType = 0x0001
  bcdUSB = 0x0210
  bDeviceClass = 0x0000  <Probed by interface class>
  bDeviceSubClass = 0x0000
  bDeviceProtocol = 0x0000
  bMaxPacketSize0 = 0x0040
  idVendor = 0x17ef
  idProduct = 0x7205
  bcdDevice = 0x3000
  iManufacturer = 0x0001  <Lenovo>
  iProduct = 0x0002  <Thinkpad USB LAN>
  iSerialNumber = 0x0006  <000001000000>
  bNumConfigurations = 0x0002
I tried found ndis or ndisgen, but with no success :(.
But after that command:
usbconfig -d 1.5 set_config 1
I got new interface "ue0":
ue0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
		ether 3c:18:a0:05:93:4c
After add IP and Netmask, the broadcast was found. I can ping the assigned IP, but still I can not access to the device using this IP - ERR_CONNECTION_REFUSED, status is not showing (Unknown)
Is it possible to do something with it? Or I need to buy some other usb or pcie card?
I want to assign the Physical NIC to VM but system does not recognized this device.
Please, help me install this card
FreeNAS 11.0-U4
wblock
Documentation Engineer
Don't use those. They worked years ago, but now...
Notebooks and USB Ethernet are sub-optimal for FreeNAS. Why are you trying to use them? If you must use the Thinkpad, isn't the native Ethernet supported?
kondisz
Ohh, sorry I missed few things, my FreeNAS working on desktop pc with native card which are connected to the main home router. And I need to connect FreeNAS to second network. So I have Thinkpad USB 3.0 Ethernet Adapter which I want to use for it without extra paying for extra hardware:
https://support.lenovo.com/pl/en/solutions/pd029741
For easiest solution probably I will buy PCI-e network card. I found dual port cards like HP NC382T (used) or NC360T (used) - each for 12-15$... or some card with 4 ports (used) also supported by FreeNAS/FreeNAS for 45$
I think it will be best way. Do You agree with me?
Thank You in advance
gpsguy
Active Member
Yes, a PCI/e NIC is an excellent choice.
